Rear wheel drive Brumby
brumby_pete
Post by brumby_pete » Mon Jul 07, 2008 1:01 pm
Hey guys, may be a silly question, but is it possible to lock the 4wd mechanism on the brumby and take out the CV joints to make it RWD??:confused: If so, what are the pros and cons. I'll be honest here, all i basically want is oversteer :Dwith minimal/reversible mods. Can't give it the old scandinavian flick because all i get is understeer and in 4wd its next to impossible to get the thing to let go.
Cheers, Pete
Jimmy G
Post by Jimmy G » Mon Jul 07, 2008 1:12 pm
Hi Pete - mine is set up that way now with an EA82T& running 5speed box. I am putting in an LSD - it is a nightmare to drive in wet as is, even cornering in dry it is a handful . Hope this helps.....jim
brumby_pete
Post by brumby_pete » Mon Jul 07, 2008 1:15 pm
lol does it just slide out? and how did you take out the CV joints and lock the 4WD mechanism??
Jimmy G
Post by Jimmy G » Mon Jul 07, 2008 2:18 pm
Just select 4WD & take out linkages to gearbox (or you have a choice of RWD or 0WD) & take out front drive shafts.
Its not ideal really - needs LSD , but far better to have AWD - especially if using EA82T or EJ22 etc.
Post by El_Freddo » Mon Jul 07, 2008 3:06 pm
I'd be wary of this move - I've heard that the transfer gears to the rear of the car can burn out if not looked after. It would be fun to do this for a little bit.
Probabily the best thing you can do is set it up similar to Brumbyrunner's drivetrain in his race unit, 4wd oversteer is so much more fun than 2wd - and a completely different kettle of fish.
My 2c
