FWD To 4WD
FWD To 4WD
I have a FWD EA71 MY Subaru. I wish to make it 4WD driva and have a dead 4WD EA82 parts car. Would this change be straight forward ie mostly a bolt on job? Anyone who has done this before I would love to hear from you. Thanks.
I would leave the EA82 if that's what you were going to do.
To get 4wd you will need a different rear end suspension setup to the EA82 setup, this may be the hard part.
The EA82 gearbox and rear diff should all bolt up with a few mods to the gearbox crossmember, the engine/gearbox bolt pattern will be the same, use the EA82 flywheel and clutch.
The parts you may need to source: Rear end to bolt under your EA71 subi, get the drive shafts while your there.
The rest will be a pretty simple process.
