MY 84 touring wagon engine wiring into an 89 brumby - Problem/parts needed:
Post by El_Freddo » Sat Jun 21, 2008 4:07 pm
Hey all.
As some of you may have heard I'm going to be attempting to shove the "sports" dash (the longer than standard dash) into Sunnie. I have the entire wiring loom from the dash forward, this should plug into and run the rear brumby wiring (stop lights indicators etc) without a problem.
The only big problem I can see is that the brumby has an auto choke and the wiring between the two cars for the engine is different. The blue plug for the engine wiring on the brumby has a plug in the 6 socket that the touring wagon wiring does not - on the touring wagon plug it has a socket at the bottom of the plug (can't remember the number associated with that socket). Both have 4 wires.
What I was wondering is: Does someone have an engine wiring loom (just the engine wiring from the blue plug into the main loom) from an 89 or like-wise auto-choke EA81 engine? If so, would you part with it?
My aim here is to slice up and splice the donor brumby engine wiring onto the touring wagon engine wiring as all the wiring is the same colour between the two systems I have here.
The reason I'm doing it this way is to avoid time off the road with the car. Also by retaining the old loom/dash etc it can be swapped back in if there are problems with the sports dash and associated wiring...
Clear as mud?
As always, any input is welcome.
