1985 subaru
1985 subaru
hi i got a 1985 subaru sedan and got an ea98 engine and i cant undo the harminic ballencer how
Hey mate
If you have a 85 Leone it will have the EA82 engine not EA89. It does not have a harmonic balancer it has a simple crank pulley, the way to undo it is on top of the bell housing is a black rubber cover pull it out and you will see the fly wheel. Turn the fly wheel till you see one of the many holes in it jam something in that hole eg screwdriver then turn the bolt on the front of the crank pulley the usual direction with someone holding the pin in the fly wheel. Its a bit hard the first time but once you have done it a couple of times it becomes real easy. It took me over a hour the first time to figure it out and a lot of skinned knuckles (bloody radiator).
Cheers Kris
Cheers Kris
- littlewhiteute
Scroll down in here to BYB's post - this is the electronic manual, the best info you'll find on the EA82 in one place.steptoe wrote:You will need to find the electronic manual in here if you not have one. too hard for me to relay at the moment
