Overheat
Overheat
Hi,
Ive got a 92 NA lib, A couple of week ago my car played up with the cooling, temprature gauge spiked to above the H on hot. Shut it down and had a look. Had water but was like it wasn't circulating. Got it home and brand new radiator and thermostat later and its got problems again.
The temprature is just going up and doesnt stop till the car is turned off. Using a lot of water ( no leaks anywhere) and about 10 seconds after the car is turned off, the radiator starts making alien noises and the top radiator hose pumps in and out and then stops squeezed together.
When i rev the car with the radiator cap off, the water is sucked into the radiator and when its back to idle it spews water out everywhere.
Start the car up again and its fine till it gets warm again.
Car still goes well, no misses and revs hard, no loss of power.
Sorry if it doesnt make much sense but its the best way that i can describe it.
My ideas are : Head Gasket
Water Pump
Anyone else here have any ideas??
Jarrod
Water Pump
Jarrod
- littlewhiteute
- FROG
get a gas test on the cooling system ........
- FROG
or fitted incorrectlylittlewhiteute wrote:Top hose squeezed together: Thermostat jammed shut.
run it with no thermostat at all to rule it out as a problem
Just be careful you dont fry the rear-most piston on the passenger side without the thermostat as you will get a hotspot on the back of the block.AndrewT wrote:run it with no thermostat at all to rule it out as a problem
Try it but make sure it is only for diagnostics otherwise you will fry the motor:???:
I would go with the gas test and a pressure test. I am thinking maybe thermo not in properly or a blockage(did you use gasket goo??)
Hooroo
Rob Forsyth
How would running no thermostat cause a hotspot on the back of the block?CPOCSM wrote:Just be careful you dont fry the rear-most piston on the passenger side without the thermostat as you will get a hotspot on the back of the block.
Hooroo
Well all i have done is bypassed the heater and its fine so i gave the core a flush out and reconnected the heater. All fixed for the minute.
Now with the cold mornings the car barely gets to half on the temp guage.
That's weird... Maybe you dislodged something that was slowing the flow of water somewhere... I'm guessing that there is a certain amount of water that flows through the heater core regardless of thermostate position.Suby Roo wrote:Well all i have done is bypassed the heater and its fine so i gave the core a flush out and reconnected the heater. All fixed for the minute.
my 2c
Well apparently the heater core is on a bypass circut anyway. When i flushed the core out, there wasn't any muck or gunk in it. The water flowed through clear and now the heater works even better than it did before.El_Freddo wrote:That's weird... Maybe you dislodged something that was slowing the flow of water somewhere... I'm guessing that there is a certain amount of water that flows through the heater core regardless of thermostate position.
my 2c
Jarrod
