car stalls when auto in gear
chubby37
Post by chubby37 » Wed Jun 04, 2008 6:15 pm
hi guys...small problem..the lib starts and revs fine but when i put the auto in gear[reverse or drive]it stalls,sudden stall.has anyone had this problem before?i need to try and get it sorted if you have some ideas as my other half is working the drags and needs the car....thanks
Suba
Post by Suba » Wed Jun 04, 2008 6:31 pm
Had this happen to mine some time ago ended up turning to shit and had to replace the trans .
Mike.
chubby37
Post by chubby37 » Wed Jun 04, 2008 7:10 pm
no no no...i just replaced it a couple of months ago
chubby37
Post by chubby37 » Wed Jun 04, 2008 8:46 pm
i just replaced the neutral switch on the auto and no luck...thought it mite have been that
chubby37
Post by chubby37 » Thu Jun 05, 2008 9:00 am
whats the chance of it being the dam converter on the auto???
Fatz
Post by Fatz » Thu Jun 05, 2008 9:08 am
how does she idle chubby?
All the breather and vacuum hoses connected in the engine bay?
I had similar issues, turned out to be a MAF hose was loose.
chubby37
Post by chubby37 » Thu Jun 05, 2008 9:18 am
starts great,idles perfect.revs really well but all goea pear shaped once in gear....very sudden stall once auto is placed in any gear??..i checked all the lines and pulled plugs appart to check them but all looks fine...i,m starting to pull my hair out over it which i guess isnt all bad as i,m mostly grey now.
