where to buy EA82 gaskets?
Anyone know where to buy gaskets for the EA82, to buy genuine parts or not??? i'm only after a inlet, exhaust also spigot bearing but the price of these new are almost $100, maybe should buy a complete set?
Spigot bearing is about $5
Genuine inlet gaskets are about $20ea
Good exhaust gaskets are $6ea
Try Coventry Auto / Burson Auto parts
http://www.subiparts.com.au
0438 887 746
0438 887 746
wow, those prices are good! I was quoted $44 ea for the exhaust gaskets (genuine parts) $24 for the intake. Bursons are just down the road i'll give them a go!......thanks for the info!Xtreme_RX wrote:Spigot bearing is about $5
When and if you get a set of exhaust gaskets, make sure the hole that the exhaust passes through is a ring that is press fitted onto the gasket - this stops the exhaust gases pushing through the gasket.
I'm currently using hi temp silicone for my exhaust gaskets. Its working a treat and is best not to hit rocks/tree roots while 4wd'n, otherwise it doesn't last long.
Spammer Post Above ^^^^^
Where do you get them? Are they any better than the pressed aluminium/cardboard ones?El_Freddo wrote:I'm currently using hi temp silicone for my exhaust gaskets.
