i have a dream. This consists of
1. wanky wagon
2. a twin turbo frontcut
i have afew concerns about the do-ableness of this conversion though. I know of only one other l-series in Australia with this conversion and that is Fatz's wagon.
The main issue i can see is the cross member. Not really sure what to do in this regard. Would scalloping the xmember to fit the dump pipes would weaken it too much?
I also plan on using the l-series d/r gearbox and seeing how it copes with twins. I spose an awd ej d/r will be on the cards soon because i cant see the ea box holding together for too long. Curious on what pressure i should try and get the pressure plate beafed too, and what clutch disc to run.
Also with the intercooler, would i better off going a waic or keeping the tmic. Keeping in mind i want it to spool up as quick as possible becasue after all, its a 4x4.
my current radiator should be able to cope with the TT setup, as its a dual core based on a single turbo EJ radiator.
would my VL turbo bosch fuel pump be able to cope with it?
thoughts/opinions/any other ideas i should be considering?
im also aware that twins wouldnt be the best for offroad situations, but i just like the idea of having a lifted twin turbo wagon
thanks everyone
