Lift kit bolts/ steering nightmare
BRUMBERTY
Post by BRUMBERTY » Sat May 17, 2008 6:45 pm
Cooee all,
After buying the WonderBrumby Mark 2 and transplanting the goodies into her I have had awful trouble keeping alignment on the front tyres.
Fair enough that I have jumped it and raced it and hauled tray loads of brickies sand up hellish gravel hills...
and its a 280 horsepower drivertrain...but these tyres were rooted in months.
At $160 a pop I was getting shat, quickly.
I found the problem..
Front crossmember lift bolts (or not really in this case).
2 out of 3 and those 2 are mild steel threaded rod!
Snapped top plate and very stripped threads where it counted.
Bugger.
Firstly assemble a trustworthy team...
Then some bits... In this case I used some EJ22 head bolts; about 20mm long but who cares, at least they are High tensile!! 6mm plate will be supporting it.
There is a huge difference between 3mm and 6mm when it comes to your life hey..
1989 Subaru WonderBrumby II
brumbyrunner
Post by brumbyrunner » Sat May 17, 2008 6:55 pm
Holy smokes I can't believe that! Where in the world did you buy those? Everybody knows you can't drink red from a tumbler!
Seriously though, where did that lift kit come from? I hope you didn't build it :)
Settlement Creek Racing
BRUMBERTY
Post by BRUMBERTY » Sat May 17, 2008 7:10 pm
Commercial grade stemless red wine glass Stuart...almost impossible for even me to spill.
Yes they do even stay on the bullbar for a short spin around Cranbrook.
Tested.
Lift was in there when I purchased her. Origin unknown.
Brown trousers when I found it though.
Post by El_Freddo » Sat May 17, 2008 10:51 pm
brumbyrunner wrote:Everybody knows you can't drink red from a tumbler!
If its a quality drop of goon it deserves to be drunk from a tubler, old jam jar or even a plastic cup... I've read that Brumberty enjoys a fine drop and would most likely know better anyway ;)
BRUMBERTY wrote:Lift was in there when I purchased her. Origin unknown.
I'd reckon! That's crazy dodgy... I don't think the wacky shop would even go that far!!!
Glad you found it before you encountered other problems with the front end - like it falling out completely!
Good team you have there too, where are the trusty chooks?
Post by AndrewT » Sun May 18, 2008 2:33 pm
yer we've always just used the bolts that come with the lift kit. I don't know many people who've made their own lift kits from scratch but yeh, you'd definitely use propper bolts.
Most of the pre-packaged lift kits I've encounted only come with the bolts for the engine crossmember not the little upper plate...normally you have to bash the standard bolts out (they are tack welded in) and use the standard upper plate.
Naturally a dirty thick bit of flat bar is better, that's what I'm going to be using on the monsterwagon.
90brumby
Post by 90brumby » Sun May 18, 2008 10:28 pm
for best results u would use shorter bolts at the top n then short bolts at the bottom giving it much more stength
but the head bolts should hold up if it happens again i would deffently b puttin short bolts top n bottom
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
subybrumby
Post by subybrumby » Mon May 19, 2008 4:42 pm
A shed full of suby bits, dog nearby, glass of red...place is like a crab pot...wouldn't be able to get me out of it.
BRUMBERTY
Post by BRUMBERTY » Mon May 19, 2008 7:34 pm
subybrumby wrote:A shed full of suby bits, dog nearby, glass of red...place is like a crab pot...wouldn't be able to get me out of it.
Which is the exact reason I have been to the big smoke (Hobart) only two or three times this year. Big Big smoke (smellbourne) just once.
Homebody mate.
Loving it too.
BRUMBERTY
Post by BRUMBERTY » Mon May 19, 2008 7:37 pm
90brumby wrote:for best results u would use shorter bolts at the top n then short bolts at the bottom giving it much more stength
Where are you putting the short bolts dude?
They are all the same length and going through the crosmember..lift blocks and then frame rails....I fail to see where you could shove ashort bolt.
vincentvega
Post by vincentvega » Mon May 19, 2008 9:21 pm
this is coming from the guy with a liberty rear end bolted to the tray of his brumby!
you cant use shorter bolts in a proper lift kit with crush tubes. You can with C section but thats a whole other kettle of fish.
your head studs will do fine! good thing you spotted the problem mate
Matatak
Post by Matatak » Mon May 19, 2008 9:32 pm
i think Tristan was talking more about the 4 Inch Lift Kits as they seem to have 2 sets of bolts for the cross member lift brackets.
top set bolting the bracket up to the Chassis and bottom set bolting to the Cross member.
they are also quite a different design to the crush tubes.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
plucky
Post by plucky » Mon May 19, 2008 10:26 pm
Regarding tyre scrubbing: I have had this problem, its usually caused by the alignment people. They just align the front end with toe in, as if it's a falcodore or something. Factory specs are 2 - 3 mm toe out. If set with toe in, front wheel drive in normal street use = equals tyres scrubbed on the outside. Feels a bit skittish in 2wd in loose surfaces too. Think about the engineering and forces when driving and it all becomes obvious.
KevinFlys
Benefits of Becoming a Member
Post by KevinFlys » Tue May 27, 2008 1:30 pm
Can you simply tell if Runescape is a great game maplestory powerleveling or not without you becoming a member? The answer to that would be, NO! Well you can make a few predictions about Runescape and see the moral of the game when being a regular user and not a member but becoming a member brings a whole lot of additions to Runescape that you would never see if you were not a member. Being a member of Runescape has so many benefits and I will try to list them all here for you. Runescape tells you them, but I'm going to detail it a few features for you here. runescape money
