question
uCb
question
Post by uCb » Fri May 16, 2008 5:32 pm
on the brumby what is with the (1)@ 40 (2)@ 80 (3)@ 110 for
Suba
Post by Suba » Fri May 16, 2008 5:37 pm
Where are you looking at this
Mike.
Suba
Ok had a longer thought about this , it would be max speed in each gear.
Mike.
Post by Gannon » Fri May 16, 2008 5:40 pm
On the speedo i assume?
Basically it is the maximum speed to do in each gear, as to not over-rev the engine. By the looks at it, if you are doing 40 in 1st, 80 in 2nd and 110 in 3rd, it means you are doing around 5200rpm and its time to change gears.
SubaRute
Post by SubaRute » Fri May 16, 2008 5:47 pm
ummm i wonder whar rpm its doing @160km? in a 3sp auto.
Post by Gannon » Fri May 16, 2008 5:59 pm
Ah an 3sp auto, i just assumed it was for the first 3 gears of the manual.
BaronVonChickenPants
Post by BaronVonChickenPants » Fri May 16, 2008 7:20 pm
In the manual it is redline for each gear, it's about 5,000 rpm.
Jordan.
uCb
Post by uCb » Fri May 16, 2008 7:41 pm
it's a 4speed manuel , and if thats what it.s for l don't think l will try it out
Post by steptoe » Sat May 17, 2008 11:43 am
early Japanese mechanical driven tacho :)
Post by Gannon » Sat May 17, 2008 2:32 pm
uCb wrote:it's a 4speed manuel , and if thats what it.s for l don't think l will try it out
Reving to 5000rpm in your Brumbies EA81 wont hurt anything cos peak power occurs somewhere between 4800 and 5200rpm.
But there is no point taking it past this point (around 5k) as you have passed the point of peak power and you are better off changing gear to put you back into the torque curve.
brumbyrunner
Post by brumbyrunner » Sat May 17, 2008 7:04 pm
Yeah, it's the poor man's shift light. And don't worry your EA81 will easily rev to those figures and beyond.
Settlement Creek Racing
Post by El_Freddo » Sat May 17, 2008 11:31 pm
Suparoo wrote:Ah an 3sp auto, i just assumed it was for the first 3 gears of the manual.
Got that right Suparoo. Every MY i've seen short of the digi dash units have these. Going for the markers is quite a noisy affair that I wouldn't want to do very often if at all!
