ej22s prone to blowing radiator hoses?
Bobbrumby
Post by Bobbrumby » Thu May 15, 2008 3:47 pm
I have driven my new to me 1995 Subaru LIberty for 1000km and its blows the top radiator hose. I cought it early when I noticed the temp guage was at 3/4 instead of just under half. Going over to the other side of town to fix it this arvo. I supose this was just unlucky or something more sinister? I got some tectalloy coolent from repco this alright for my engine? 50/50 mix recomended
<div>1990 Brumby 275 k km , holley 180, 2 inch zorst</div>
Post by El_Freddo » Thu May 15, 2008 5:11 pm
Yeah that Tecta alloy stuff should be good. A radiator hose blowing - it could have been that its one from the factory and has finally failed. Or it could be that it was one from the factory and you have a leaking headgasket that's pressurising the cooling system. I'm not sure how common this is with the EJ's but I do know that the EA's a prone for headgaskets.
How many k's has the car done?
Captain Obvious
Post by Captain Obvious » Thu May 15, 2008 5:45 pm
would be a good idea to change the thermosate as well, maybe be seized shut and pressurizing the rad
Post by Alex » Thu May 15, 2008 7:19 pm
the rad hose is 13 years old. What can you expect! Its just one of those things that happens unfortunately.
Bobbrumby
Post by Bobbrumby » Thu May 15, 2008 7:44 pm
Yeh i thought as much alex. What a bugger it is to refill an ej22 with coolent, ended up pouring it down the air relief screw on the opposat rad. tank to the cap, after toping up from cap of course. I will see how she goes but seems to be working back at regular opperating temp. oh yeh only 160k km
Matatak
Post by Matatak » Thu May 15, 2008 7:46 pm
Atleast u noticed before any big damage was done to.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by AlpineRaven » Thu May 15, 2008 10:02 pm
Maybe long time due service!
EJ22s doesnt blow any hoses unless they're old..
Bobbrumby
Post by Bobbrumby » Fri May 16, 2008 5:05 pm
yeh the hose is old, it has that white coating that subaru puts on their coolent pipes. The ej22 has been very well looked after full subaru service history, It is hard to find an oil leak on it, and the only one is just oil vapour below the ps pump. I recon this is a good life from a 15 yo piece of rubber also the top hose runs hotter too so. I am thinking of doing the thermostat and rad cap tho just for peice of mind.
uCb
question
Post by uCb » Fri May 16, 2008 5:16 pm
on speedo what are the numbers (1)@40km/h (2)@80km/h and (3)@110km/h on the brumby's
