Post by NachaLuva » Fri Feb 07, 2014 8:55 pm
Thanks mate, & thanks for showing me how to do it :mrgreen:
Also replaced the boot clamp on the rear inner CV. Bit disappointing as it had only just been replaced when I bought the axles but the silly bugger cheaped out & reused the OEM clamps & it started leaking within days :evil:
Post by NachaLuva » Thu Feb 20, 2014 10:00 pm
Sealed up some of the holes in the cabin. 1 big one at the front next to your feet & another for the seatbelt recess. Both huge with no restriction to water flooding in. Both now coverd in plastic:
CC unit moved up next to glove box:
Got this big wombat trip on Saturday but wont have time to seal up both sides, just have to make sure I dont dunk the drivers side too deep lol :rolleyes:
Kalbarri_baru
Post by Kalbarri_baru » Thu Feb 20, 2014 10:14 pm
New KYB Struts / shocks and King springs all round, also new air filter (Thanks to Paul at RSR Performance in Rockingham).
Next to be done is Rotors, Brakes and Calipers, also a slight whine in the gearbox might get looked at so might as well get the clutch done at the same time
WayneO.................
Post by NachaLuva » Fri Feb 21, 2014 1:47 pm
I used playdoh on my Foz today. Dont worry, its says ages 2+so I'll be fine :p
When I get a chance I'll reveal all in my build thread ;)
Tigger
Post by Tigger » Sun Mar 02, 2014 7:39 pm
New Mags and Tyres for the Foz :D
Proton mouse
Post by Proton mouse » Sun Mar 02, 2014 9:26 pm
They look great with the extra bit of detail in them. Are they still subie rims or after market?
Proton mouse
Post by Proton mouse » Sun Mar 02, 2014 9:30 pm
Lol, I was very happy with a jigsaw puzzle I did. On the box it said 2-5 years but it only took me 6 months to do!
Post by Silverbullet » Sun Mar 02, 2014 9:32 pm
Today I finally corrected my crooked steering wheel that was 2 teeth out on the spline...been like that for months but always too lazy to correct it :rolleyes: Also cleaned it, can not believe how much human slime accumulates on a steering wheel. It's actually quite disgusting when you think about it :shock:
Tigger
Post by Tigger » Sun Mar 02, 2014 10:27 pm
Proton mouse wrote:They look great with the extra bit of detail in them. Are they still subie rims or after market?
Thanks :) They are still Subie rims, they came off the current shape Forester :)
Tigger
Post by Tigger » Sun Mar 02, 2014 10:29 pm
Silverbullet wrote:Today I finally corrected my crooked steering wheel that was 2 teeth out on the spline...been like that for months but always too lazy to correct it :rolleyes: Also cleaned it, can not believe how much human slime accumulates on a steering wheel. It's actually quite disgusting when you think about it :shock:
In our old Pulsar we had the same thing from the previous owner on the sil of the door where they had always rested their arm while driving! It is very gross!
Subydoug
Post by Subydoug » Mon Mar 03, 2014 10:40 am
Made a spare wheel carrier for my Wagon. Now I can fit things under the hood and if I do get bigger tyres at some point Il have somewhere to stick the spare.
Doug
Post by Silverbullet » Mon Mar 03, 2014 4:42 pm
That's awesome Doug! :) Any chance of some detail pics? How is it hinged?
coxy
Post by coxy » Mon Mar 03, 2014 6:56 pm
Spent the weekend cutting out rust and making new sections around the blanking plates where the rear foglights fit in some markets, came out perfect and needed minimal work to finish, Then again I have been doing that sort of stuff for years and have a folder, Mig and 3 Tigs which helps.
Subydoug
Post by Subydoug » Tue Mar 04, 2014 11:19 am
Silverbullet, here you go. Didn't wanna spam it in here,
showthread.php?p=228045#post228045
Doug
Post by NachaLuva » Tue Mar 04, 2014 12:02 pm
Subydoug wrote:Silverbullet, here you go. Didn't wanna spam it in here,
Doug
Really excellent job, great fitment :mrgreen:
MY-Wagon
84 Wagon project
Post by MY-Wagon » Tue Mar 04, 2014 3:56 pm
Bolted hand brake cables for liberty rear discs into my 84 wagon.
Removed fly wheel after reading that just using MY large pressure plate and L Series clutch plate won’t last. I need to machine old fly wheel or find an L Series fly wheel. And order an L Series pressure plate. For 5 speed conversion
Does anyone in Brisbane have one {EA82Flywheel} that I could pick up?
Trying to decide if I should redrill top of strut towers to take 3 bolts ‘cause the later ones have a nice bearing instead of grippy bush setup.
Also did a lot of looking and pondering and writing lists of next things to do and solve.
PS Anyone out there got an L Series Fly Wheel?
T.Farm.Brumby
Post by T.Farm.Brumby » Tue Mar 04, 2014 7:34 pm
MY-Wagon wrote:Bolted hand brake cables for liberty rear discs into my 84 wagon.
I have a full '85 L Series that I might part out, EA82, N/A, 5 Speed FWD box. mechanicals are all spot on as far as I can tell/have experienced with it.
Tom.
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'89 Brumby "Brumbylicious"
'03 Outback "Uma"
'05 Forester
Post by Silverbullet » Fri Mar 07, 2014 5:21 pm
Got a new exhaust today! :) 2" from they Y pipe back, but also got a new Y pipe in 1 3/4" because why not, it looks nice and shiny :eek: Straight through resonator and muffler as well. It is slightly louder when inside the car than the older stock system, but driving around when you're in the car it sounds almost exactly the same, little disappointed there but if you're actually behind the car it sounds like this (see below) Performance gain? little if any, best part is I can't smell exhaust in the cabin any more! :p Hopefully it has solved that problem.
*Edit* Note the "phwoar!" in the last seconds of the vid...that's mum complaining of the smell :oops: the car is burning a tiny amount of oil and probably also running rich in higher revs due to my piece of wire forcing the secondary open on the carb.
https://www.youtube.com/watch?v=KEgqNlR ... e=youtu.be
Proton mouse
Post by Proton mouse » Fri Mar 07, 2014 8:35 pm
Go the boxer burble!! Nice one :)
FujiFan
Post by FujiFan » Fri Mar 07, 2014 11:45 pm
+1 for the boxer sound, Silverbullet :)
Being new exhaust sections, some of the odour will go after a while!
J.
