Post by Silverbullet » Tue Sep 03, 2013 9:23 pm
Picked these up on the way home today, looks like my weekend is sorted :rolleyes: $150 each at auto pro, anyone had any experience with this brand? I've got a 36mm socket too, just the ball joints to contend with. I'm hoping these will sort out some of the massive vibration issues in the ute.
Post by NachaLuva » Thu Sep 05, 2013 3:39 pm
Picked up my plated LSD the other day:
My wheel nuts arrived today. They are a custom item with ball seats to fit Audi 15" forged rims onto Subie hubs
15 min later my hubcentric rings arrived, also for the Audi rims
Subydoug
Post by Subydoug » Sat Sep 07, 2013 7:35 pm
Pulled my finger out and fabbed up the old airbox to go onto my weber. Gave it a lick of paint. Looks 100% compared to the old stock weber one. Also less induction note ;).
Also a quick wash,
I like my MY :D.
Doug
Cliff R
Post by Cliff R » Sun Sep 08, 2013 12:41 pm
Nice red on the air filter, wish I had a sun roof and I see you too have the pretty much useless roof luggage rack.
I pulled my rack off and am prepared to live with (8) screws in the roof till I get around to bogging them up and repainting.
I am in two minds on if I will also pull the rack strips off the roof too. The could be handy with Rola racks in not dropping stuff onto the roof.
Dont know yet.
Subydoug
Post by Subydoug » Sun Sep 08, 2013 2:28 pm
Yeah Ive used the roof rack twice to carry a ladder the whole time Ive had the car. Ive also got another frame Im going to put on it at some stage. I prefer the look with the roof rack on the touring model. Sunroof is awesome, keeps the car cool very well.
Ive done a bit more driving with the "new" old airbox now and hot damn! anyone who's running a weber with the standard thin airfilter and tin lid should consider swapping this over. Engine sounds so much better and butt dyno registers a little bit more up and boogie off the line.
Doug
Post by NachaLuva » Sun Sep 08, 2013 3:38 pm
Subydoug wrote:Sunroof is awesome, keeps the car cool very well.
I would LOVE a sunroof in my Foz :twisted:
Have you had your butt dyno recently calibrated lol :rolleyes:
It certainly looks good & I'm sure would help with the engine breathing more freely. Nice job ;)
purp
Post by purp » Mon Sep 09, 2013 1:56 pm
Not me, but a facebook friend. And not exactly improved...
Post by Silverbullet » Mon Sep 09, 2013 5:47 pm
Oh dear, how on earth did that get there? ;)
purp
Post by purp » Fri Sep 13, 2013 12:55 pm
Silverbullet wrote:Oh dear, how on earth did that get there? ;)
Apparently it came out through a non standard hole...
Post by NachaLuva » Fri Sep 13, 2013 4:41 pm
Conrod out the top of the block...ouch! :cry:
Yesterday I picked up my '97 WRX rear shafts with new inner boots. My plated LSD rear is one step closer! :cool:
Post by El_Freddo » Fri Sep 13, 2013 8:23 pm
I'm impressed that he got the whole thing out in one piece, they usually bend then break up and exit...
Post by steptoe » Fri Sep 13, 2013 9:39 pm
Hooked up a pair of marine 12V outlets - in the side of the Brumby console, just below the two bracket securing screws. They are both on a latching relay (22AMP factory jobbies of course) to protect circuit from start up spikes/surges . Intention is to run a USB plug in adapter 2.1Amp with built in resetting surge/spike protection. A little momentary on push button switch is used to power up the relay once engine is running. Jammed a little 3A fuse holder in the mix. All the wiring tucks ups natly, with the relay wrapped in foam so no rattles :)
Post by Silverbullet » Sat Sep 14, 2013 7:05 pm
Not really improving my soobie but today I installed 3 flood lights under the car port, so now I can improve my soobie after dark! :p
I recently bought 2 of these
http://www.ebay.com.au/itm/181112010350 ... 1497.l2649
For this exact purpose. I wanted lots of light but not lots of power draw, since I'd be running 3 lights plus any power tools I might need off of 1 socket. So LED seemed to way to go and they are certainly bright enough, not even the brightest ones. And today when I went to funnings to get all the cable and plugs I saw identical LED units for $99 each! :eek:
For anyone who buys these lights make sure you open them up before you wire them up, both of mine the ground wire wasn't connected to anything :confused:
Post by steptoe » Sat Sep 14, 2013 10:38 pm
jaycar got similar looking sized /priced things - rechargeable ones I think they were ?, bloody too bright when tested out in daylight !!
GLfoos86
Post by GLfoos86 » Tue Sep 24, 2013 5:11 am
ea82 engine install. vacuum diags still confusing. no confidence in progress. extremely rough idle and cherry cat led us to new coil and plug wires(new spark plugs installed earlier). next day, rough idle but cooler catalytic converter. now from cranking(?) oil dripping from? any help would b beneficial.
Post by Silverbullet » Tue Sep 24, 2013 10:17 pm
Today I received 3 big boxes of bits for my wagon, to help keep me cool on those long hot drives home in summer :) Huge thanks to Proton Mouse for packing it so perfectly for me, another big step towards making the wagon more like a modern car. Can't wait to get stuck in to this lot.
Having a look at my FSM I realize how crazy complicated the shutter/ducting system is for these things; about 5 different shutters and blinds that open and close depending on dial and vent flap settings :shock:
It's like christmas when you get home to something like this on your doorstep
I wonder what this could be
Post by NachaLuva » Wed Sep 25, 2013 7:39 pm
Did my rear wheel bearings today.
Quote for genuine was $540 for both sides incl seals, parts only!!! I got them from Repco for $114 for 2 complete kits incl castellated nuts (with discount) plus $30 each side getting them pressed into the hubs.
Driving home today, I noticed the new bearings were hot, too hot to touch. Is this normal? My front bearings were warm only. What could be causing this?
tambox
Post by tambox » Wed Sep 25, 2013 9:48 pm
Tight bearings = heat
L serious, still.
Proton mouse
Post by Proton mouse » Wed Sep 25, 2013 10:35 pm
NachaLuva, that certainly doesn't sound normal for them to be too hot to touch. Was it just one or the both sides that were hot? And how fast and for how long was the journey home. Possibly at 100kph for an extended time might make the tight tolerances of new bearings heat up.
Post by NachaLuva » Thu Sep 26, 2013 3:58 pm
OK, figured out the prob. I was at my GFs house so didnt have a torque wrench or FSM so didnt know the correct torque. I knew the Libs are done up b****y tight so just did the same, guessing about 220-250 Nm. FSM says 137 ft lbs or 186 Nm for pre '02 Foz, so I definitely did em up too tight.
Loosened off the nuts today & knocked the axles back in a smidge then torqued em to exactly 137 ft lbs. I went for a test drive on the freeway, when I got back they had barely any warmth but it had just hailed! So air everything was pretty cold. I'll try again when it warms up a bit but I think they should be fine now.
Just goes to show...always torque everything correctly!!! :oops:
