Powerlines Feb 11th
i dont like your tone brendan :P
better get ur leone back on the road :P
my tone? im typing :P
leone is kind of on the road :P
i pushed it round last w/e
Hunter S. Thompson
Hunter S. Thompson
bahhaahhahhaa...thats the way :P
the best way would be a ej22 and some 25's
or at least running
or at least running
Hunter S. Thompson
Hunter S. Thompson
i think u should go for option a.
u know ill be round to help if thats the case
Ok im in... Vidler knows how to push the right buttons with me so i have decided to come.
Just turn up Lapsed... there will be more than a few spare front seats... including one in mine.
Dave
Dave
SuBaRiNo wrote:Ok im in... Vidler knows how to push the right buttons with me so i have decided to come.
Dave
lol. hahahaha.
whats wrong with your car lapsed? anything i can help with?
09 Forester XT Touring Wagon
- suba_dooba
so you need a new strut top 4" lift block? i can remove the stud and reweld in another. only take maybe and hour... the other option is removing all of the studs, drilling out holes, welding in larger bolts (maybe 12mm) and drilling out the strut top mounts in the engine bay... that will be strond as f u c k. on the bright side, when i had a 2" lift in it, i had stripped one bolt, sheared another, both on one side.... took me yonks to fix it and it never gave way. Never trusted it though and didnt do any serious off road work.Lapsed wrote:how good are you at manufacturing a strut to lift block??? cause the thread is stripped and i dont want to f things up till i replace it. i may call on your perfect welding skills to replace them soon
I can fix it this arvo if it only needs a new bolt. drop into bunnings on the way and grab some high tensile ones. you know where i live.
Give me a call on 0415615015 sometime today. working till 12 then fitting the welded diff to subi's car. your free to come round then and use my stuff to remove strut.
ok guys, i think im going to be pulling out.
Something stuffed with the cluch last night, i cant get it into gear, and when i do(after lots o pumping of the pedal) its really hard to change through gears, like i have to use 100% of my muscle. Last night i had to start the car i gear and use the starter motor to sort of jump start the car!
Does anyone have any ideas? Big problem im going to be in rotto until about 5.30 this arvo!..
cheers guys
cheers guys
Should be just the clutch cable adjustment on the gearbox end I'd say.
Yeha just an adjustment i would say... by the sounds of it it was put together in a hurry and there is still a lot of things still not bolted on.
I hope u know there was no way i could make it to Tims that night to help you with the car... had stuff on... infact that night and friday night were the only 2 nights that week that i had stuff on.
Dave
Dave
CB UHF CHANNEL 16..
Will be used unless we change it when we get there... People without a CB should either borrow one or buy one. These can be found for as little as $30 at some stores.
Dave
Dave
- suba_dooba
They can also be had for free if borrowed from certain unsuspecting members!
(me)
(me)
