Bantum's '85 Brumby ...
Collection of automotive design / construct projects by Bantum ...
Moderator: Bantum
Post by El_Freddo » Sat Dec 19, 2015 9:35 pm
That's what I've done with all my dash swaps - wound the clock to the current reading on the dash being replaced.
I used and air gun to whiz through the k's ;)
Side Stepped ...
Post by Bantum » Mon Jan 25, 2016 1:20 am
Yep will wind 'em back when I get round to it ... :)
In the mean time, got round to cleaning up the Running Boards ...
And test fitting :
Seems to fit Ok, just need to straighten them a bit, find some new mounting hardware & install them ... :twisted:
Cheers, Bantum ...
Tigger
Post by Tigger » Mon Jan 25, 2016 11:45 am
They look great!! :)
Post by El_Freddo » Mon Jan 25, 2016 1:12 pm
Yeah mate those running boards look awesome!
I was going to go for a set on a 45* angle but never got around to doing it...
Sewn Up ...
Post by Bantum » Mon May 02, 2016 4:59 am
Will be a while before I get round to installing the dash / running boards ( as I still have to do the rust preventative thing ) - So have been looking at what else I can do in the meantime ... :/
Tried out my sewing skills :
Back side :
Will see how it turns out ... ;)
Ciao, Bantum ...
EL Wires ...
Post by Bantum » Tue Oct 04, 2016 1:39 am
Well I got some more bits to go with interior ...
And goes somewhere here ...
Test fitting ...
Should look ok ...
Note : item can be found here : EL = Electroluminescent Wire
Keep on trucking, Bantum ...
Fender Washers ...
Post by Bantum » Tue Oct 04, 2016 3:23 am
Also got some bling to add somewhere :
Not sure where they go yet ... :shock:
PWJDM - seems to be a weird code for something ?
Ciao, Bantum ...
Proton mouse
Post by Proton mouse » Tue Oct 04, 2016 9:50 am
I like those 'bling' washers! Not sure about the "for off road use only" warning?? You'll be in big trouble if you drive on the road with them!! haha
Post by Bantum » Wed Oct 05, 2016 3:30 am
Yes only saw that after I'd opened it, so can't really do much about that now ... :(
I'll not be using it for holding much weight, as I think they are covering themselves from claims if something goes pare shaped ... ;)
Ciao, Bantum ...
Full Scale ...
Post by Bantum » Fri Dec 02, 2016 6:13 am
Got the drawing I had done earlier printed out @ 1:1 ...
Checked to see how good it measured up :
& laid out some vinyl to make sure it all fits :
Found a few errors that will need tweaking when I get round to it ... :/
Hope to do some more over the Christmas break ...
Ciao, Bantum ...
Telltale ...
Post by Bantum » Fri Dec 02, 2016 6:28 am
Also got round to getting this laser cut :
Fitted the LEDs to go with it :
& found some green plastic :
Have to get round to painting the Tell-tale back in Black now ... :rolleyes:
Ciao, Bantum ...
Post by El_Freddo » Fri Dec 02, 2016 4:11 pm
Top work mate!
Laser cutting - I wouldn't even know where to start looking for that service!
I'm keen to see how these door cards turn out ;)
Post by Silverbullet » Fri Dec 02, 2016 5:53 pm
Bantum wrote:Also got round to getting this laser cut :
Well that's one way to get a low range light! Very nice work, going above and beyond :cool:
BUT! there's an error! The factory low range light says "Lo" not "Low" !!!
Actually yours looks better, with the wheel diagrams as well.
And those door cards, I can tell those are going to be seriously nice :o Would you mind terribly if I copied them for my wagon? :oops: I'll pay royalties honest!!
Post by Bantum » Fri Dec 02, 2016 11:01 pm
Yeah, my thoughts were when I did the first draft ( which was same as the original ) that it didn't 'look right' + something was missing, so ended up making it slightly different with few tweaks that I wanted & made it look as if it came from factory ... :cool:
P.S - Added a few extra details to the headlight as well ( just in case you missed it ) ... ;)
Painted the back in black :
& Peeled the cover to reveal :
I'll have to see how it turns out & post some more pictures when I get round to installing it ... :)
Cheers, Bantum ...
Covered ...
Post by Bantum » Wed Jan 11, 2017 6:37 am
Over the Christmas period I finally got round to start fixing the Steering Wheel Cover :
All have to do now is to finish hand stitching it ... :/
( read 'it takes forever' )
Cheers, Bantum ...
Score ...
Post by Bantum » Wed Jan 11, 2017 7:11 am
Found some spare doors :
Innards look ok :
All I have to do now is clean them up & swap them over ... :)
( read it may take a while )
Cheers, Bantum ...
Proton mouse
Post by Proton mouse » Wed Jan 11, 2017 12:13 pm
Excellent score, GLF5 power window doors none the less!!
Post by El_Freddo » Wed Jan 11, 2017 4:28 pm
I love this:
First recent post: "hand stitching takes forever"
Most recent post straight after the first recent post: "found some spare doors".
So I guess the hand stitching of the steering wheel is done then??
Winning ...
Post by Bantum » Sat Jan 14, 2017 6:12 am
Ha - Nah Bennie, I still need to do the fitting to the actual wheel ( there's been a hold up on the rubber underlay which needs fixing ) which might take a while ... :/
P.S. - added a few more shots of the process though ... :)
Yeah the doors were a total 'wow' find moment ... (I wasn't even looking for them ) So yeah as soon as I saw 'em, said 'yep I'll have those' ... :win:
Will post some more updates when I get round to it ... ;)
Cheers, bantum ...
Sidetracked ...
Post by Bantum » Sat Jul 29, 2017 4:20 am
Sorry to report - Its been very slow in the 'working on this' department - As I've been sidetracked by health issues ( compressed disc L5 ) & will attempt to do some updates when I can ... :(
Have done some work on the gearbox - will post some updates on that later.
Also just went back through the thread & updated as many of the links as I could ... FU PB ... :/
Ciao, Bantum ...
Return to “Bantum’s Works”
