- Rodeo4jake
- TOONGA
Yes I have liberty inner CV joints on brumby shafts with brumby outer CV joints.60766244 wrote:Ordered a new CV setup for the Brumby. Turns out she's a custom jobby.
Hopefully done tomorrow arvo!
Anyone else have custom CV's on their EJ converted machines? :\
You need to talk to RSR555 to find out how it was done.
Im pretty sure it was first gen liberty cups and brumby race and bearings.
But RSR will know for sure.
Cheers, Text sent. I seem to be getting mixed messages all over. Hopefully I can sort it by tomorrow.TOONGA wrote:Yes I have liberty inner CV joints on brumby shafts with brumby outer CV joints.
- Silverbullet
Today I cut some thick rubber mat for the back of the ute. Dad brought home this 6ft roll of solid thick rubber (about 6-8mm, must be conveyor belt stuff?) from Paramount Browns. Heavy too I struggled to manoeuvre the roll around by myself. Anyway got around to cutting it to length and cutting out for the wheels, realized that the wheel arches aren't identical on both sides
And here it is now, looks real nice and will be bloody hard wearing
Also finally got around to fixing the latch in the tail gate. I always thought it was the two mechanisms at each end that were seized but turns out it was the crappy contraption in the middle...designed to suck is an understatement
Basically a piece of the handle side of the latch was fouling and jamming up against the swivel part that the two pushrods bolt to. This same part was also jamming up against the inner skin of the tailgate and locking into place.
I had to cut and file some bits, bend some things and space the handle out with some washers, but I got there. Works perfectly now and I can live with the handle sticking out that .5mm extra
I'd either be sealing the edges with some really, really tough rubberglue to keep out the dirt and water, or drill a load of 20mm holes evenly spaced over the whole mat.
I've seen a lot of trays rusted out with a large sheet of un-punctured rubber in the back. Gotta ventilate to drain well and minimize the rust!
Mine has a large mat that came from Clark Rubber that looks like a giant rubber welcome mat.
Looks really flash how it is however!
Edit: Also, on topic, Lift Finished! Car is working again.
- Silverbullet
I'm aware of the problem of water getting trapped underneath, if it was my choice I would have gotten the rubber like yours but dad just brought this home one day so had to use it
I'll just keep a close eye on it and take the rubber out to clean underneath regularly.
I saw the massive expanse of rubber, and knowing the toughness of conveyor rubber thought, "What an epic thief-proof tonneau that would make.":rolleyes:
Looks great imho.
Looks great imho.
- Brumby Kid
Instead of drilling. Go to Clark rubber and buy a sheet of it pre drilled.
Looks good in my ute, cut it to size etc. and neat holes evenly spaced.
Cheers Cam
Cheers Cam
You wont drill it, you will need to get a large hole punch, a lump of hardwood and a hammer to make the holes neat
- Silverbullet
Bought some fish oil and brush on seam sealer for the wagon resto. Put some oil down the A pillar behind one of my welds and quickly saw it seeping out through some pin holes that aren't even visible...this stuff penetrates!
Good stuff, but even the de-odorized oil still smells fishy
- Silverbullet
Fixed a little problem that's been bugging me since I did the engine swap; nearly the entire clutch pedal stroke is free-play. With the crappy little adjustment nut wound all the way in still too much free play. I had enough travel to change gears, but recently it's been getting worse and today I could barely select 1st, clutch touching the floor and it wasn't dis-engaged.
So when I had a spare 20 minutes at work I made a new adjustment nut...out of tool steel (because that's all that was laying around
) Made it alot beefier and had clearance at the front end to clear the non threaded part and get me some more adjustment. I had to form-grind a special HSS cutting tool to turn the ball shape that fits into the clutch fork, and then machine 2 flats on the round nut to 11.7mm which fits my 12mm spanner perfectly. Then a simple M6 thread and it was all done. Swapped the old crappy nut over after work, 10 minutes later and I can change gears again! friction point in the middle of the pedal where it should be, makes it so much easier to drive.
Before anyone says the clutch is worn out; it's not. I put a my nearly new one in with the engine, and I definitely put the friction plate in the right way around. Dunno why there was so much free-play though. For a clearer picture of what I made, here's a picture...not of the real thing though since it's on the car.
How? I sometimes get that pretty badB00sting wrote:...fixed the godamn reverse being difficult to get into problem.
Took my Brumby down to Methams Mufflers Belmont and he got my exhaust off my driveshaft with the blowtorch. Booked in only 2 hours before I got it done! Took 20 minutes, they charge me $20. Very good service.
Only brake lines, front brakes, gearbox plate and wheel caps to go!
Well mine was really bad since the 2" body lift. Basically cut and welded the gearstick on a slightly different angle. It no longer fouls on the 4wd linkages. But it can also be sloppy bushes. Shifter still sloppy but goes into reverse easy as now.
-97 Landcruiser
-97 Landcruiser
- Kustomchris
