Post by steptoe » Sun Dec 23, 2012 11:44 am
Installed a front mount only style Bosch finger cutter thermo fan made in Chermany from a wrecker.
No idea what it is out of but got it from a loose AC condensor that had neat little threaded clips in the fins x 3 securing fan to it. It did not come with neat frame work for universal fitment- like the Panasonci units I spied on an awesome EJ20G conversion in a Brumby.....
Was the only fan of a slimline variety I could find. Nearly had it all dummied up as a pump side of the radiator until I felt the air holes of the fans motor were now facing forward and could go phut with water entry etc, so mounted it to the front with even greater fitment ease.
The finger guard was held in place by three screw studs with M6 at the top end of each stud. I drilled out & through the stud mounts holes, fitted up with odd M6 bolts and nuts.
In the radiator catch support panel a factory hole was very useful, so too a factory captivated nut for the top bracket, then found another captive nut doin nought until today, for the third and final securing ponit.
It is fixed to body quite soundly and will not need to be disconnected and removed anytime the radiator has to come out.Gonna keep the clutch fan on the pump for the time being. Need to bridge a trigger off the other fan for new fan relay
Uploaded with ImageShack.us
Oh, and there is my discreet (in position only :D ) air horn compressor , needed a little cut out from the grille, but is out of the wway of the rest of the crap under the bonnet
Post by sven '2' » Thu Dec 27, 2012 7:34 pm
Not on a subie, but
Installed a pair of Hella Supertones - they are very LOUD!!
Highly recommended for country drivers
Brumby Kid
Post by Brumby Kid » Thu Dec 27, 2012 7:50 pm
Are the super tones a nice manly sound like a truck?
Or just like a normal car horn nice and girly/ tinny.
Cheers Cam
Dads Car: 02 Impreza WRX STi
Post by sven '2' » Thu Dec 27, 2012 8:13 pm
A truck...a big one!
Post by El_Freddo » Thu Dec 27, 2012 9:46 pm
sven '2' wrote:Installed a pair of Hella Supertones - they are very LOUD!!
Sounds like what I need :P What sort of coin would I be looking at for a set of these? Ruby Scoo's horns are pretty dead after being under some muddy water :???: Good time to replace/upgrade I think!
One thing I've got a plan for is my AC. Dad and I spent about an hour poking around the wrecks to piece together what I need to get the EJ pump and EA system to marry together. Then it's a case of shelling out for the gassing of the system :evil: Apparently the cost of this has gone through the roof!
Post by sven '2' » Thu Dec 27, 2012 10:09 pm
El_Freddo wrote:Sounds like what I need :P What sort of coin would I be looking at for a set of these? Ruby Scoo's horns are pretty dead after being under some muddy water :???: Good time to replace/upgrade I think!
Investment for these bad boys = $49 delivered from the Bay of Es
There is some debate that now that they are made in India (as opposed to Germany) the quality is off, but I cannot see it.
My wife described them as 'obscene' - all I heard was 'blah blah awesome'
Post by sven '2' » Thu Dec 27, 2012 10:13 pm
I had a mobile regas from a guy Steve (Rising Sun) uses for the RS - similar vintage, was $120 incl a 3 month warranty which I thought was pretty good?
Post by El_Freddo » Thu Dec 27, 2012 10:25 pm
sven '2' wrote:I had a mobile regas from a guy Steve (Rising Sun) uses for the RS - similar vintage, was $120 incl a 3 month warranty which I thought was pretty good?
That sounds good. I've heard that since the carbon tax the cost of the gas (which I believe LPG can be used) has gone through the roof.
I'll get the system cleaned up and closed then some quotes before I settle on someone to do the work...
Brumby Kid
Post by Brumby Kid » Thu Dec 27, 2012 10:39 pm
sven '2' wrote:A truck...a big one!
So a nice deep throaty boaaaaaaaarrrrh?
Like an air horn?
Simple strait plug/ wire up to existing horn wires?
Cam
Post by sven '2' » Thu Dec 27, 2012 10:46 pm
Brumby Kid wrote:So a nice deep throaty boaaaaaaaarrrrh?
Like an air horn?
Cam
Louder than an air horn
Just needs a relay - about a 3 beer job
Post by steptoe » Fri Dec 28, 2012 6:26 am
Mine are louder than what is permitted on road - yet effective for dudes concentrating on their coffee, mobile phone conversation, earphones or big padded headphones, her shapely backside on a pushbike seat etc.
I got 'em for $12.50 plus post ~ $20 from one of those websirtes that send you deals from that date forward so select a junk email address first smartshopper ??? I'll come back with it after I clear my junkmails address.....
SoldSmart with the dot com dot au
I bought a pair of them delivered cost me $34. The pacjkaging claimed it came with relay and wire ? it didn;t have it in there, the plstic hose was cheap nasty pvc clear , an upgrade to Goodyear pink general purpose hose and some 8mm barbed joiners or T from sca was all that was needed for a proper blast :D
Post by El_Freddo » Fri Dec 28, 2012 3:49 pm
steptoe wrote:I bought a pair of them delivered cost me $34. The pacjkaging claimed it came with relay and wire ? it didn;t have it in there, the plstic hose was cheap nasty pvc clear , an upgrade to Goodyear pink general purpose hose and some 8mm barbed joiners or T from sca was all that was needed for a proper blast :D
Are you talking about electric air horns Jonno? The units that Sven has linked to are your electric horn replacement/upgrade - I don't think a copper could book you for these as they're not air horns which are not allowed by RWC - at least in Vic, but there are loads of them out there!
I was toying with the idea of those air horns that sound like a train just for shits and giggles :twisted: But they're costly. These seem like the way to go.
Rodeo4jake
Post by Rodeo4jake » Fri Dec 28, 2012 5:53 pm
Hey guys,
I worked for an old school mechanic in a workshop & he told me that big old Mercs & the like had these super loud dual tone Hella horns. One day on a trip to a wrecker to get parts for a job I got some to put on my ute I owned at the time. They came off an old 560 merc & they were loud!:mad: Might give you guys an idea of where else you might find these. At the time the wrecker gave em to me, but I was in the trade then.
Cheers Jake
Post by steptoe » Fri Dec 28, 2012 7:44 pm
Arr no, missed the electric bit :oops:
that extra fan at the front whirrs away but does not keep the engine any cooler - must be the thermostat keeping things as warm as before.
Learnt my lesson before playing with subies and adding relays to switch accessories and used both wires of the AC fan to switch the new relays 85,86 terminals with no independent earth wire to 85 causing mishap :)
Post by steptoe » Fri Dec 28, 2012 7:45 pm
El_Freddo wrote: I was toying with the idea of those air horns that sound like a train just for shits and giggles :twisted: But they're costly. These seem like the way to go.
Whoa !! Bennie, can you link me to those horns that sound like a train please. A mate would give his left nut for a pair :D
Brumby Kid
Post by Brumby Kid » Fri Dec 28, 2012 8:31 pm
My mate with the troop carrier would give both his nuts for a horn that sound like a truck or train.
For a lifted troop carrier the current horn sounds like a Prius.
Cam
Post by Silverbullet » Fri Dec 28, 2012 10:44 pm
You can buy kits online, I think there's a company dedicated to selling them. Rather illegal on a road car though.
Post by steptoe » Sat Dec 29, 2012 6:27 am
No matter where they go just as long as my mate can push a button and get that awesome train horn sound going - maybe the workshop doorbell :D
Post by El_Freddo » Sat Dec 29, 2012 10:15 am
steptoe wrote:Whoa !! Bennie, can you link me to those horns that sound like a train please. A mate would give his left nut for a pair :D
There's this item on fleabay.
For more options, search for "train horn/s" - there's a couple of actual train horns there at the moment. Still keen for a set but really need to find a place to mount them :(
Post by steptoe » Sat Dec 29, 2012 11:24 am
back to the topic ' electric train horns'
