Stretch's Brumby.
- Brumby Kid
Your lights dim at low revs isn't bad earths.
Older Suby's don't use relays in the headlight wiring.
In the headlight circuit it loses voltage and so headlights aren't as bright.
Whack a relay or 2 or 4 in there and your headlights will be great!!!
Cheers Cam
Cheers Cam
the 2nd Gen brumby has twin relays (quad headlight) under the dash near your right knee. They are cylindrical. I assume the 1st gen would have a relay in the same spot. Your problem is the alternator not keeping up volts with low revs. Could be the battery taking excessive charge (on the way out), the regulator unit in the alternator is dying, engine revs too low at idle, too much electrical load on the alternator (spot light, stereo and amp?) at idle. The standard wiring is poor and well worth upgrading but won't solve the dim lights at low revs problem. You can also fit a Nissan alternator in there with a higher rating from memory...Brumby Kid wrote:Your lights dim at low revs isn't bad earths.
Cheers Cam
- Stretchomatic
Replaced a tonneau hook the other day as it broke off some where down the track.
The kit was about $15 at supercheap. So Ive got a few spares.
[ATTACH]4100[/ATTACH]
Thats what I started with. It was broken on a weird angle so the drill wouldnt dig in. I ended up using a drift punch to quickly knock it in.
[ATTACH]4097[/ATTACH]
Then you just slip the hook onto the rivet.
[ATTACH]4098[/ATTACH]
And pop it in.
[ATTACH]4099[/ATTACH]
Now all I need is a tonneau cover... -_-
Cheers, Stretch.
And pop it in.
Cheers, Stretch.
- uploadfromtaptalk1367622471215.jpg (27.21 KiB) Viewed 9783 times
- uploadfromtaptalk1367622453764.jpg (65.33 KiB) Viewed 9783 times
- uploadfromtaptalk1367622438438.jpg (59.9 KiB) Viewed 9783 times
- uploadfromtaptalk1367622424590.jpg (53.5 KiB) Viewed 9783 times
- Stretchomatic
Check the condition of both fuel filters
- Stretchomatic
- Stretchomatic
RSR Gets the bonus points here. I pulled the rear filter out and chucked a spare pulsar one we had in the shed in it. Not the best fit but will do until I get a hold of some subi ones.
Revs so much more freely than i remember and accelerates really well too. I think its been causing troubles for a while and i have been blaming the tired carby.
Cheers, Stretch.
Cheers, Stretch.
Thanks Stretch, I could do with all the bonus points at the moment. Glad you got it sorted with a fairly easy fix.. some problems can take forever to find.
- Stretchomatic
Yeah I really didn't expect it to be the filter. The way it just started playing up. Now with a new filter I can see it had been causing troubles for a while, especially at 110kmh you could feel the motor hunting and surging. That seems to have cleared up now. So I'm pretty happy now haha.
Cheers, Stretch.
Cheers, Stretch.
- Stretchomatic
Maybe a good time to run a fuel treatment through your system and see what happens - hopefully a good clean out!Stretchomatic wrote:Yeah I really didn't expect it to be the filter. The way it just started playing up. Now with a new filter I can see it had been causing troubles for a while, especially at 110kmh you could feel the motor hunting and surging. That seems to have cleared up now. So I'm pretty happy now haha.
Nice set of wheels on your... er... wheels
- Stretchomatic
- Stretchomatic
I did this two or three weeks ago now. It's very easy!
My advice to anyone reading is to make the sides of the metal pieces steep rather than not, otherwise the disengage mechanism will just slide over it without disengaging!
I used some model brass, 5mm wide (from memory), bent it to shape, heated it on top of the wood stove and pressed it into the plastic as the plastic melts a little bit. Once cooled those metal pieces will not be going anywhere.
Best mod/fix for the MY's I reckon! Well worth the effort of pulling the steering wheel and the steering column cowling.
This repair needs its own thread. I have put up with this problem for 14 years on one Brumby. Now wonder if the part is available - FROG ? I did imagine if only some genius could come up with a spring metal clip that had its necessary rises in it, araldited into place.
What are you using to hold them metal bits in place ?
- Bantum
Already done one here : showthread.php?t=22371
Just the process of melting the metal into plastic it seems to hold ...
Cheers, Bantum ...
Cheers, Bantum ...
If you can send me one that needs repair I can do it for you Steptoe. If you can't send a spare one I should have one on a parts car I can pull and repair then send to yousteptoe wrote:This repair needs its own thread. I have put up with this problem for 14 years on one Brumby. Now wonder if the part is available - FROG ? I did imagine if only some genius could come up with a spring metal clip that had its necessary rises in it, araldited into place.
Thanks Bennie. My current Brumby actually cancels, sometimes cancels on roundabouts when it shouldn't - think I actually like the non cancel rustic mod
Was thinking a drill jig could be made for these if round rod worked. Curiosity might see if a part can still be bought new.
Certain my 84 Brumby had a harsh life up in Moree region. The dash was all busted up from sunburn, seat belt was pretty hairy, first crank had nasty score marks in it, the odo stopped at 88,000km or 1,088,000km - not sure. Think the heat melted the speedo gear lube of the nylon cogs and onto the cockys boots. The turn cancel was well worn like everything else by its 14th birthday when i got it. My 92 utes odo still turning nice at 398,800km - mad sure it was well greased when it came out for some dash work.
The dings in the 84's tray, the scratches - one tough little ute before I got it
