Show us yer tools
Phizinza
Post by Phizinza » Thu Jul 16, 2015 10:05 pm
FujiFan wrote:There was bound to be some bunny fugger on here that was going to post something to that effect :p
And we have a winner :rolleyes:
J.
I was reading through and couldn't see anything to the effect. It had to be done.
dfoyl
Post by dfoyl » Sat Jul 25, 2015 8:19 pm
Can you guess what caused this ? A 36mm socket and a MY wagon was involved...
Post by Silverbullet » Sat Jul 25, 2015 9:38 pm
Ah yeh :rolleyes:
Well at least yours bent, mine just snapped on one of those axle nuts ;)
Post by steptoe » Sun Jul 26, 2015 9:00 am
show us how long the extension bar on it was !!
dfoyl
Post by dfoyl » Sun Jul 26, 2015 11:40 am
Was only a 40cm length of lead pipe. The bearing had seized up and tightened the nut to the axle. Good brand too, Minimax.
Post by steptoe » Sat Aug 29, 2015 9:23 am
found out that these are a T & E Tools line up
near essential for mucking around with our Subie alloy castings. Also cleaned up mild steel threads.
The one above is not included in the kit sold - is rare M10 1.0mm pitch does brake line fittings and was pretty pricey compared to the kit. $10 ea piece and 15.00 freight. Though, price real tap and dies in this size , not much change from a green note!
Ethi69
Post by Ethi69 » Wed Oct 07, 2015 10:39 pm
[ATTACH]4660[/ATTACH]Didn't make this but just bent the prongs of this angle grinder tool so that I could turn the front brake calliper piston back in on the brumby. Got me outta the shiz
Kind regards Ethi... Sent from iThrash
Post by steptoe » Sat Feb 20, 2016 2:33 pm
rear brake drum adjuster tool
where is our toolmaker ?
the hole for the slider bar is at an approximate angle 120/60 to enable to flip the 'socket' from its 6mm to 8mm square
is an old like 40 or [more likely] 50 year old VW adjuster tool
reckon if you bent an old 1/4" drive long extension and use the female end for the adjuster, may get same function
