The GRUMPY Brumby
chridk
Post by chridk » Mon Dec 09, 2013 5:54 pm
Sunday At Lakeside, I almost clean up my mate on lap two, due to me having warmed my tyres and him not.
http://youtu.be/uGcIelJDAy0
Post by Silverbullet » Mon Dec 09, 2013 6:29 pm
Jeez that thing moves! Nice vid. I see you still have the factory standard squeeky clutch pedal :p
Post by RSR 555 » Tue Dec 10, 2013 10:57 am
Awesome vid and yes very close call on the 2nd lap. Nothing better than the chirping of those black round things
chridk
Post by chridk » Sat Jun 28, 2014 8:54 pm
For those Interested, the Grumpy Brumby has been to Lakeside Raceway again, got a new PB of 63.5
http://youtu.be/WYx5CQTUVNQ
Post by Bantum » Sun Jun 29, 2014 12:34 pm
Looking good there ... :)
Grumpy is still bit tail happy though, do you have rear sway bar ? It might also help if you put a few sand bags in the back when you race to put a bit more weight there ... ;)
Keep at it ... :p
Cheers, Bantum ...
Cliff R
Post by Cliff R » Sun Jun 29, 2014 2:06 pm
Those vids are awesome.
The sun in the eyes looks like a right pain.
These old Subies with the high powered engines are incredible.
chridk
Post by chridk » Thu Jul 03, 2014 12:42 am
Cheers Folks,
There's no rear sway bar yet, and no sand bags going in the back because keeping weight down and its a fun challenge driving a slightly tail happy car ;-)
Post by Bantum » Thu Jul 03, 2014 9:10 pm
All good fun ... :)
I was thinking more of a balanced approach however : If you get the weight more evenly distributed / spread over all four wheels, front & rear ( as in a normal situation in the Brumby would be approx. 60 % on the front ) it would be easier to handle ... ;)
So how much does your car weigh ? ( For the best effort - it has to be a total with you included - if you don't mind me asking ) The guys at the track should have scales you can borrow ( ask nicely ). Then you can do the sums to work out how much the rear needs ( I'd estimate approx. 50 to 80 kg ) probably slightly more on passenger side to keep it balanced ... :twisted:
I would also suggest a more permanent way to mount the weights would be to get some metal plate made ( with correct weight ) that could be bolted to the fame ( lower the better ) which can be adjusted etc. or removed if not needed. Do a bit of testing & see how it goes ... :p
Don't forget the sway bar too ... !
Cheers, Bantum ...
chridk
Post by chridk » Fri Jul 04, 2014 12:01 pm
Haha, cheers Bantum
I think the ute + me (120kg) is about 1000kg, going on the scales at the tip but it is still only a rough guide.
The Grumpy will get a bit more weight when I put a cage in it and the only weight I've left up the back is the tow bar & relocated battery ( mainly for a tow point if the worst happens).
Chris
chridk
Post by chridk » Wed Jul 09, 2014 9:38 am
A bit of motorkarna action in the Grumpy ;-)
http://youtu.be/I261HS5itXo
taza
Post by taza » Sat Sep 27, 2014 4:14 pm
What shocks/suspension are you running up front? Coil overs? Brumby top hats or redrilled strut towers to accept 3 stud?
Standard front swaybar?
chridk
Post by chridk » Sun Sep 28, 2014 12:50 am
The Grumpy has HSD coilovers, a sway bar from an auto MY & custom made strut tops from 4mm plate steel ;-)
chridk
Post by chridk » Sun Sep 28, 2014 1:11 am
Here's the different swaybars, brumby top & auto bottom....the auto swaybar gives just enough room to clear the gearbox.
Rodeo4jake
Post by Rodeo4jake » Wed Oct 01, 2014 8:58 pm
G'day there mate,
Check out the Addco swaybar available for the front from the US. The bend goes under the exhaust instead of over. Would be heaps larger than the one you're using as well.
Post by El_Freddo » Sun Oct 19, 2014 11:18 pm
Is that the same make as your rear sway bar you got for your brumby?
chridk
Post by chridk » Fri Feb 20, 2015 8:02 pm
Another vid from last year
http://youtu.be/cKZ6eqI9LgU
Post by Bantum » Fri Apr 17, 2015 2:54 pm
Looking good there Chridk ... :)
How'd you go with upgrading the sway bars, got them installed yet ?
Also it was a bit hard to tell from the video, but did the 180sx suffer much damage ?
Cheers, Bantum ...
chridk
Post by chridk » Tue May 05, 2015 10:16 am
Cheers Bantum,
I haven't done anything with the Brumby this year as work has been very quiet.
The 180sx was a right off, went into the wall nose first at about 60kph. It had a full cage which served it's purpose and the driver walked away.
