revmax
Post by revmax » Wed Aug 15, 2012 6:25 am
Yer Al, where did ya get it !
Post by TOONGA » Wed Aug 15, 2012 8:10 am
MTB92
Post by MTB92 » Wed Aug 15, 2012 8:30 am
I have also made do with a thin stanley knife with the blade removed and a pair of long nose pliers. obviously not as good as the actual tool, but a suitable make shift solution.
Post by steptoe » Wed Aug 15, 2012 8:33 am
Looks like the KD tool, but there must be another one for the bands that are a bit like a belt with a clasp that needs tightening past the hole (like sucking yer guts in) to get the keeper in the hole
alang
Post by alang » Wed Aug 15, 2012 11:37 am
that's the place where i've been buying from but been using the Australian sellers like onlineautoparts and Suzukisuper Fast turn a round and friendly service.
http://www.ebay.com.au/itm/CV-Joint-Boo ... 106wt_1397
http://www.ebay.com.au/itm/2WD-4WD-L-Se ... 616wt_1397
with the boot kit you have a choice inner or outer
alang
Post by alang » Wed Aug 15, 2012 11:46 am
revmax wrote:Yer Al, where did ya get it !
The axle is the drivers side out of the ute taken it apart all the balls and parts had minimal wear on them had to tap the balls into the holes. i have a spare of a L Wagon but didn't know if making noises had been replace from the car just need to pull it down to see.
the boots of ebay from suzkisuper have been buying from them over the last year or more.
Post by Alex » Wed Aug 15, 2012 12:28 pm
all part shops have those band tightening tools.
Post by El_Freddo » Wed Aug 15, 2012 4:02 pm
Alex wrote:all part shops have those band tightening tools.
And they're the bee's knees of CV tools - can't go past them for their ease of use and how quickly and painlessly the job can be done.
B00sting
Post by B00sting » Sat Aug 18, 2012 4:31 pm
spent quite a few hours attempting to polish the wheels i put on recently. i got a drill attachment from bunnings and some cutting/polishing compound with some cutting and polishing wheels.
fiddly business!
-97 Landcruiser :D
scriptchip
Post by scriptchip » Sat Aug 18, 2012 4:50 pm
Install a half inch steel rear diff bash plate, nothing shall touch my diff :)
~Subaru brumby 1990 - 14's , alloy bullbar , tow bar , 1/2inch rear diff bash plate. .... so far.
~ 2000 Outback - street project
Mothers vehicles.
2012 foz
1985 L series
Brumby Kid
Post by Brumby Kid » Sat Aug 18, 2012 7:16 pm
scriptchip wrote:Install a half inch steel rear diff bash plate, nothing shall touch my diff :)
Sh1t!!!
That is rather big!
Where did you get it?
Cam
Dads Car: 02 Impreza WRX STi
scriptchip
Post by scriptchip » Sat Aug 18, 2012 10:08 pm
Off My l series, nearly crushed my chest when i dropped the diff.
Pro tip; let it drop ahah.
It lowered my suspension by 2mm, i need new shocks
haha
Mothers vehicles.
2012 foz
1985 L series
Brumby Kid
Post by Brumby Kid » Sat Aug 18, 2012 10:22 pm
scriptchip wrote:Off My l series, nearly crushed my chest when i dropped the diff.
haha
Haha whoops.
Do you know where I could get one?
Cam
scriptchip
Post by scriptchip » Sun Aug 19, 2012 11:54 am
I would not have a clue, too me its just a heavy L with a oval cut out for dif inspection/drain. then bolts to the front of the diff and where your support arm is that holds the diff. ill send you photos if ya need
Mothers vehicles.
2012 foz
1985 L series
Tweety
Post by Tweety » Thu Aug 23, 2012 5:37 am
Can now concentrate of cosmetics. Two vW Scat belt guards protect fingers- a legal requirement in Victoria.
There are two belts now and too wide for a single guard.
3 wing nuts with welded bolts make detachement easy and quick.
taza
Post by taza » Thu Aug 23, 2012 12:49 pm
Fitted my new bullbar to the Foz...
Post by El_Freddo » Thu Aug 23, 2012 4:13 pm
Looking good fellas!
Tweety, those guards are quite complementary compared to what I thought they'd look like!
Taza, your foz is looking very "grown up" now :D
Tweety
Post by Tweety » Thu Aug 23, 2012 8:25 pm
Yes Bennie it looks good....like a double VW :grin: they werent quite long enough about 30mm short but one shouldnt have their fingers at the bottom of the crank pulley anyway.
JamoT
Post by JamoT » Fri Aug 24, 2012 12:07 am
Looking good Taza!:cool:
Post by guyph_01 » Fri Aug 24, 2012 12:59 am
Taza lets hope you don't rip the bumper off this time:p
