Subie Boys , Lovey80 Resto
1111giles
Post by 1111giles » Sun Aug 29, 2010 7:58 pm
El_Freddo wrote:Hmmm... I don't recall my EJ's ECU needing to know when the gearbox is in neutral... Interesting.
I want to go home now!
Nosey little bugger's these ECU's are these day's:mrgreen:
Giles.
Post by RSR 555 » Mon Aug 30, 2010 2:06 am
From memory the neutral wire is for 2 reasons..
1.. The cruise control (turn off if accidentally knock into neutral)
2.. Lowers engine revs when idle for more than 20 seconds (keeping engine coolant temp down)
rtcb65
Post by rtcb65 » Wed Sep 01, 2010 6:16 pm
Oil light and temp are now wired to computer. Also in the middle of making and fitting a earthing kit.
rtcb65
Redneck Rick.
last celtic warrior
Post by last celtic warrior » Thu Sep 02, 2010 5:21 pm
Getting to the point of being able to see the final form. Then quickly replicate for the other side. I'm pretty pleased with the design, especially considering it's just made up as I go along...
Steve.
Post by El_Freddo » Thu Sep 02, 2010 9:21 pm
I'm jealous of those scorpion rims! I'd love to have a set in the mail for Ruby Scoo!
rtcb65
Post by rtcb65 » Fri Sep 03, 2010 5:28 pm
Earthing kit now finished and wired in. Now half way through cutting down and putting together the L series shifter set. Even making it a bit towards a short shift.
Steve is abit further along on the front bar.
rtcb65
Redneck Rick.
last celtic warrior
Post by last celtic warrior » Sat Sep 04, 2010 10:00 am
A couple of clearer photos of the bar corner as it has now shaped up. Hopefully I can get the other side to look half as good...
Steve.
rtcb65
Post by rtcb65 » Sat Sep 04, 2010 7:06 pm
Gear stick set and range lever all cut down and put together ready to go in .
rtcb65
Redneck Rick.
rtcb65
Post by rtcb65 » Fri Sep 10, 2010 6:16 pm
Gear stick set and range lever all cut down and now installed.
Engine stay rod cut and remade up to suit this set up.
Here is a pic of what the gearbox lock will look like once mounted in the dash.
rtcb65
Redneck Rick.
last celtic warrior
Post by last celtic warrior » Sat Sep 18, 2010 3:28 pm
The air cleaner was just not going to fit right, so I hacked it apart to see why and put it back together the best I could manage...
The first image is actually the modified air cleaner, sitting where it should.
Steve.
1111giles
Post by 1111giles » Mon Sep 20, 2010 3:30 am
'where there's a will - there's a way eh ?
Nice work guy's. looking forward to seeing more.......:)
Giles.
Barry1956
Post by Barry1956 » Fri Nov 12, 2010 9:04 pm
Hit a snag, or just other priorities atm?
rtcb65
Post by rtcb65 » Sat Nov 13, 2010 11:44 am
Priorities, rules and parts.
rtcb65
Redneck Rick.
rtcb65
Post by rtcb65 » Sun Nov 28, 2010 3:03 pm
One Crossbred Performance liberty sump bash plate. Now modded and fitted up on the brumby.
Wow, the reflection of the shed floor.LOL.
rtcb65
Redneck Rick.
Post by TOONGA » Sun Nov 28, 2010 3:38 pm
that looks really good and gives me an idea of what I need to do to cover the same area on my brumby
rtcb65
Post by rtcb65 » Fri Dec 03, 2010 9:55 am
TOONGA wrote:that looks really good and gives me an idea of what I need to do to cover the same area on my brumby
We think it looks the part. With a little bit of adjustment it seems to fit really well.
rtcb65
Redneck Rick.
rtcb65
Post by rtcb65 » Fri Dec 03, 2010 9:57 am
One step closer. Steve has started making the other side of the bar.
rtcb65
Redneck Rick.
Backyard_Brumby
Post by Backyard_Brumby » Sun Jan 02, 2011 6:27 pm
Hey guys,
Love the look of the sump bash guard, went onto the crossbred site and it says they have ones for forrester and outback, (no liberty) will these fit? if not how did you manage to acquire your one?
Can't wait to see the finished product because so far it is looking great
[SIGPIC][/SIGPIC]James :D
rtcb65
Post by rtcb65 » Mon Feb 21, 2011 4:24 pm
Backyard_Brumby wrote:Hey guys,
It must be a outback plate. Not much difference between outback and liberty. All you have to do is contact Jeff at CROSSBRED and let him know what you have and he will let you know which one you will need.
rtcb65
Redneck Rick.
rtcb65
Post by rtcb65 » Mon Feb 21, 2011 4:26 pm
Just a little fit up of the bar to see how it is fitting.
rtcb65
Redneck Rick.
Return to “Subie Boys”
