Not sure. Where's the detent ball in for the low range in the part time 4wd box? I think it's in the same spot.
Rear Honda calipers are twist in also. They have a pair of slots in them so you can use some 5mm steel bar as a lever.
I've yet to drill a hole in the back of the Subaru pads to install a roll pin (so that the pistons don't wind themselves in & out)
1.5:1 EA Part Time Lo into EA Full Time
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
:???:Previous rides:
Nah, it's in the rear housing with all the other dedent balls. There's a locking mechanism that makes a rod longer than it actually is by the use of a hollow tube section, one of the dedent's lock it into place - from memory anyway, I played around with it for ages to try and understand how it worked so I could put it back together...wagonist wrote:Not sure. Where's the detent ball in for the low range in the part time 4wd box? I think it's in the same spot.
Thought as much, but I reckon they'll be the easier set to twist in than the fronts!wagonist wrote:Rear Honda calipers are twist in also. They have a pair of slots in them so you can use some 5mm steel bar as a lever.
The good thing about the L's AWD box is no centre LSD - hand brakies
