Suparoo's TF035 & WAIC install *** Almost Finished***
Post by Gannon » Wed Jan 23, 2008 11:29 am
Not that im trying to push much more fuel through, the main purpose i installed the FPR is the stock one was toast. Under boost, it would only raise about 2-3 psi and was causing me to run lean, but now, its rich all the way.
Wont fitting the 280 brownies make it run much richer under normal driving? I know of a programable fuel adjuster for under $100
How much $ were your dyno runs? I assume that was in Port.
Will have to catch up soon mate
Post by Gannon » Sat Jan 10, 2009 3:35 pm
Just another update
I made a new air filter to turbo intake pipe. The factory one that i chopped up to fit the TF035 i think was leaking.
Just some exhaust pipe mandrel bent to the shape i wanted.
Painted and ready to install. I used a 2.75" to 2.5" silicone reducer and a 2.25" 270deg elbow cut back so it would fit.
Installed
timmo
Post by timmo » Sat Jan 10, 2009 6:28 pm
Looks good. Did you end up having to do the headgaskets?
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
Post by Gannon » Sat Jan 10, 2009 7:19 pm
Ive been lazy and haven't done it yet. Its not bad, cos i have been driving for months now and only filled up the water 3 times, and hasn't overheated since i fixed the fan (i reinstalled the engine driven fan)
