Hatch Supercharger progress
SuBaRiNo
Post by SuBaRiNo » Tue Oct 30, 2007 11:44 pm
OK here are a few recent pics including the not completed pipe work.
Dave
ChPLAT
Post by ChPLAT » Tue Oct 30, 2007 11:48 pm
Nice job mate. Looks awesome.
Past rides-
1989 Brumby
Current ride-
MY06 Liberty 2.5i Sedan
Post by Subafury » Wed Oct 31, 2007 12:49 am
your battery is a gel/dry cell one isnt it? hence why its ok to be on its side?
Lapsed
Post by Lapsed » Wed Oct 31, 2007 7:00 am
Very nice Dave. It was meant to be there.
SUBARU OFF-ROAD RECOVERY VEHICLE
SuBaRiNo
Post by SuBaRiNo » Wed Oct 31, 2007 7:56 am
Nar Acid Battery.. leaks all over my motor. What do u think Matt??
Dave
BaronVonChickenPants
Post by BaronVonChickenPants » Wed Oct 31, 2007 8:45 am
SuBaRiNo wrote:Dave i think i need you to come over and check this thing out... im seriously scared of this thing.
How much pressure should i be expecting after the super charger... seams the more i rev it the more pressure... i thought the pressure was meant to stay the same no matter what RPM.
Dave
Dave the pressure is relative to the intake air flow, eg: in theory it should provide 6 psi above the normal intake airflow, higher revs=more air flow=more pressure required to maintain that 6 psi.
Hope that makes sense.
Jordan.
Post by El_Freddo » Wed Oct 31, 2007 12:41 pm
I so want to hear this thing howl!
Give it some dave, you'd know what you're doing with another re-build yeah?
SuBaRiNo
Post by SuBaRiNo » Wed Oct 31, 2007 8:40 pm
Hmm done some more stuff on it tonight... i think i have stuffed up in a bad way. Seams i think i have done this all wrong and it is going to require a little more work than i thought... more details later.
Dave
Post by El_Freddo » Thu Nov 01, 2007 10:14 am
SuBaRiNo wrote:Hmm done some more stuff on it tonight... i think i have stuffed up in a bad way. Seams i think i have done this all wrong and it is going to require a little more work than i thought... more details later.
Ah the suspense is killing me!!!
SuBaRiNo
Post by SuBaRiNo » Thu Nov 01, 2007 9:21 pm
I have got the throttle body on the wrong side of the Super charger... which could have ended very badly.
Worked out what to do to change it without it looking bad or doing dodgy stuff. Saturday should be the big day. Really isn;t too much to do what i need to do... i also have a plan how to make it like real SMIKO!
Dave
Dave
Matatak
Post by Matatak » Thu Nov 01, 2007 9:42 pm
wt...going after is not the right way?
dont u need it after to creat the vacuum in the manifold when u try n press ur brakes?
me is confused now
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by AndrewT » Thu Nov 01, 2007 9:55 pm
with the throttle body after the supercharger, when the engine is idling (butterfly closed) the supercharger is still trying to ram all it's air in. Thats why the charger was jamming up, skidding on its belt, and blowing the pipes apart.
Throttle body before the supercharger controls the air going in, which in turn controls the forced air comming out and going into the manifold.
I *think* thats it :)
Post by D3V1L » Thu Nov 01, 2007 10:04 pm
that would be correct andrew :)
SuBaRiNo
Post by SuBaRiNo » Thu Nov 01, 2007 10:05 pm
Yeah thats the ticket. I know it sounds like a pain to change but it will be easy... parts came with the SC kit when i got it.
Dave
Matatak
Post by Matatak » Thu Nov 01, 2007 10:08 pm
AndrewT wrote:with the throttle body after the supercharger, when the engine is idling (butterfly closed) the supercharger is still trying to ram all it's air in. Thats why the charger was jamming up, skidding on its belt, and blowing the pipes apart.
hmmm yer i get that part i did wonder first off wat wuld happen with the air going nowhere (obviously not good lol)
but that doesnt answer this part -
Matatak wrote: dont u need it after to creat the vacuum in the manifold when u try n press ur brakes?
does it need fittings between the Throttle body and the Charger for the brake booster to work when he tries braking.
im also interested to know how ur relocating the Throttle body Dave :p
SuBaRiNo
Post by SuBaRiNo » Thu Nov 01, 2007 10:15 pm
Custom my friend... C U S T O M
Im just starting to get my head around it all... don't worry your young mind about it Matt.
Dave
Post by El_Freddo » Fri Nov 02, 2007 11:11 am
SuBaRiNo wrote:i also have a plan how to make it like real SMIKO!
Are you getting some shiny bits and getting alex to polish them for you? :p
Matatak wrote:dont u need it after to creat the vacuum in the manifold when u try n press ur brakes?
Maybe the vacuum could be taken before the charger as well (but after throttle body). I'm sure there'll be some vacuum behind the throttle body when the charger is trying to suck air in...
Dunno if this is the case but it makes sense to me (but i don't have a supercharger or a degree/good knowledge of physics)
Cam
Post by Cam » Sat Nov 03, 2007 3:26 pm
couldn't you just plumb a bov, which should stop the hoses blowing off as the throttle closes?
SuBaRiNo
Post by SuBaRiNo » Sat Nov 03, 2007 7:12 pm
It's pretty complicated Cam... so ya can;t exactly do that.
Update: IT'S RUNNING!!!!
Just need to remount and stuff about with the accelerator cable and some mild wiring and it will be ready for a test drive. Im guessing i will get to drive it about lunch time tomorrow.
Big thanks to Devil Dave for coming over today... helped me to keep on trucking on with it when i was close to giving up for the weekend. I had some dramas with hoses calapsing under vacume this time... we got it sorted though.
Dave
Post by D3V1L » Sat Nov 03, 2007 7:18 pm
oooooooOOOOOOOOOOOOO hatchie growls :D
