EA dual port heads
- velocityboy
I have never seen a pic like that, that shows the exhasut ports, very nice. That would make sense, I couldn't understand why you would go to the trouble of producing those heads and not changing the exhaust ports, but they obviously did.
Unfortunatley the EJ in a car would just be too easy and cheap compared to SUB4 heads. I was talking to a friend just yesterday who is into ultralight aeroplanes and surprisingly he said a modified ea81 is a prefered option for them because of it weight over an EJ.
PS has anyone got a pic of EA81S heads?
- TOONGA
Twin carb heads you say ... what about a rebuild thread on a twin carb motor?
http://www.ultimatesubaru.org/forum/top ... -81-build/
Noice pikturs .... mmmmmmmm its soooo puurrrrty
I wish I still had my wagon
PS it isn't very in depth on the rebuild part but it does have head pictures
You could always do this:
from the top it would look like the safari motor...
# EA82 AWD 4EAT,
If you have them please PM me
# EA82 AWD 4EAT,
- Willy Fisterbottom
I got a quote on the Flygas Heads:
We offer you a head die-cast alloy “G All Si 9” fully machined, with seats valves installed and guides installed .
Eight valves (4 inlet and 4 exhaust) and N° 8 upper valves spring retainer .
Eight holes for spark-plugs M12 mm X 1,5mm
Injector holes drilled at 14mm (or your choice)
Volume combustion chamber 40cc (plus/menus 1,5%)
Without springs (you can use original).
Without cotters key (you can use original) . Weight 4,1Kg (plus/menus 4%)
•The budget cost for One pair of Cylinder Heads is ……………...…….1840Euro (920 Each)
•Your Prices if you buy one pair of Cylinder head is …………………..1760 Euro (880 Each)
•If you buy Two pair of Cylinder head became …….…………….…….1580Euro (790 Each)
That seems like a really good price I reckon.
All the head work done - seats in, guides in, you'd just have to lap the valves and assemble them! And steptoe if the sub4 heads are similarly priced that's even better, I thought someone said they were around ten thousand dollars a pair?
# EA82 AWD 4EAT,
# EA82 AWD 4EAT,
I thought the price was reasonable too. What I gather was $10000 was for a complete running SUB4 engine, looks like SUB4 may have gone out of business as no links to their site work. I've been looking on aviation sites for used Subaru aero engines but have only found an EJ20 setup for $6000 US and a EA82T in Australia for about $3000.
- Bantum
Another engine I will have to add to the list ...
showthread.php?t=22606&page=4
Will try to find some more info on this SUB4 as well ...
Add : Found this : http://www.ultralightnews.com/sunfun2000/sub4.htm
Cheers, Bantum ...
Cheers, Bantum ...
