Silverbullet wrote:Oooooooooooh me likey that one piece tail shaft! how much did it cost ya?
Well... $550
![Neutral :-|](./images/smilies/icon_neutral.gif)
if I am going to be honest. It was a business that serviced the mines, the other one in town I rang said they couldn't do it with all the work they had from mining companies. (things in the mining sector are meant to be slow??) I mean I know I paid too much in comparison to what others have paid but it looks like they did a good job. As long as it's centered and balanced I don't mind paying extra for a job to be done correctly. I was expecting around $300... but it wasn't to be. (Ohh, and I love this car - no expense spared for my baby!)
4 months is a ridiculous waiting time
![Sad :(](./images/smilies/icon_e_sad.gif)
Don't care how busy they are that is unacceptable IMO. Obviously don't know much about Subarus if they put the gear on backwards, and telling you they checked the end float like that...something smells fishy here.
Yeah, it's not totally their fault. They didn't order the pistons as I had asked so I got a little annoyed and did it myself. They were always promising to ring me but never did which just annoys me. I value honesty and I just don't trust them. To be fair the work they did looks top notch but only time will tell.
The Wiseco pistons were a special order that had to be made - took over a month but I knew that when I ordered. It's all a learning curve and if I build another engine (I hope so) I would be more organised/do things differently. But that is part of the fun...
steptoe wrote:Turn the flywheels over to make sure it is the same at the back. EA82 and EA81 flywheels differ on the other side.
The difference between EA82 225mm flywheel and EA81 225mm flywheel is in the step, one is 21mm, the other 23mm - make sure whatever way you go the step of the flywheel matches the step of the clutch
As for crank holes between EA81 and 2 - dunno yet !
I spacered my starter out with a simple cut out of 1.6mm aluminium sheet from memory
L series and EA82 are swear words at my house.
![Wink ;)](./images/smilies/icon_e_wink.gif)
It's a flywheel off a late model Brumby. I have been to the clutch shop to ask about getting a clutch kit. He seemed very knowledgeable and he said there is only two clutches for the Brumby/L-Series. The 8" and 8 3/4" - the splines, pressure plates etc are the same. So I'm not understanding the 1.5mm machining off the face and what it achieves - is it just so you don't have to space out the starter, or is it to get the correct clamping pressure on the clutch? I mean I am happy to get it done but I just don't understand what I am achieving. I like to create the illusion that I have some idea when I go to the shop...
