Can't go to work this morning, have a look why
Post by Silverbullet » Sun May 27, 2012 5:48 pm
Really? Brumby doors are longer? Phew that's good to know now, I thought they were all the same and nearly asked for a Brumby door :eek:
Anyway spent most of today getting the door to fit better, and I got one more bolt in so that's 5 of 6, couldn't get the last in for love nor money so it's staying out until the resto. I had 5 bolts in but the door still was about 10mm too low at the back, had to loosen the bolts holding the hinges to the pillar and lever hinges up with a crowbar whilst tightening bolts down to bring the rear up again. Still not perfect but good enough, just have to close the door a bit harder or close it halfway then nudge it shut.
After that I did the wing mirror which was easier than I thought; took measurements from the dud door and transferred them to the new one and drilled 2 holes. I was so close I drilled through the blank captive nuts on the other side, pity I didn't have a tap set to cut a thread in them. I just drilled through them and also the thicker inner skin to use a nut and bolt, trimming the bolt down so it didn't foul the glass. Only downside is now to take the wing mirror off the glass has to come out :) I will probably end up welding the nuts to the inside one day. Glass didn't need any adjustment by the way, seals nice and snug against the rubber.
That was all the hard part done so then it was a matter of replacing all the interior, front guard and cowl panel. Now it's all done! I definitely have inconsistent panel gaps around it but I don't care, if it doesn't leak I'll be happy. Also the paint is a slightly different shade (less faded) than the old paint, and the bumper strip is wider with chrome on it which looks a bit odd.
AshR
Post by AshR » Mon May 28, 2012 10:25 am
least it's back together without too much time hunting for parts :( still sucks that it happened.
thunder039
Post by thunder039 » Mon May 28, 2012 10:54 am
nearly the same color...
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
Post by Silverbullet » Mon May 28, 2012 5:52 pm
Nearly the same. I thought all MY's that are silver are the same silver and my old panels are just faded, but on second thoughts it probably is a different silver.
Driving around today I noticed the door creaks every now and again, usually under heavy acceleration or heavy braking but not always. Could this be simply because the door is misaligned or is it something more serious?
Post by steptoe » Mon May 28, 2012 6:09 pm
one bolt missing :) or catch needs a little Lanotec. My Brumby door creaks too
Cliff R
Post by Cliff R » Mon May 28, 2012 7:24 pm
New door looks good.
Just out of interest what is you paint code mine for the 82 model touring wagon is colour code 15 (Silver)
