Venom: H6 Gen2 Liberty GX
New motor swapped in. Took a lot longer than expected because I ****ed up by removing all the shims, which of course meant the cam lobes scrapped on the edge of the buckets and got damaged. A bit annoying, because it wasn't the straight swap I had planned. Luckily I had a full gasket kit on hand, because I ended up swapping out the cams from the old motor. In the end it wasn't too complicated, and I got to practice disassembly on the old motor first. I was kinda happy to reseal the inner timing chain cover too.
Result is the new motor is in, new exedy clutch, pressure plate, clutch fork, thrust and spigot bearings. Valve clearances are all within spec. Flywheel machined locally just before they closed for Christmas. I found that my old flywheel had been machined flat, no good. They should have a small .5mm step between the clutch and pressure plate surfaces. I suspect this was the cause of some of my bunny hopping issues, along with a softly sprung no name brand clutch. The old clutch had 6 little springs compared to the Exedy with 4 large(r) springs.
The old motor was leaking from pretty much everywhere. Rear main, the little gasket next to the rear main, inner and outer timing chain covers, valve covers. I didn't check the valve clearances on it, but I've definitely regained some performance and fuel economy.
I've got a few, but not many pictures to upload. I was pretty focused on just getting the job done
No need for a supercharger with the fresher motor, made me realise how much the old motor had been lacking.
Anyway got a bit slack with the photo's during the motor swap. Heres the only one of the new motor:
New clutch fork, pivot point, thrust bearing and dust boot installed.
Old motor pics.
Got leaks? Add the oil it was burning through too.
Old motor pics.
Hard to say, the clutch was shuddering on the flywheel before. Whether that was the step or just didn't bed in properly I'm not sure. It's only about a .5mm step, so it'd be within the wear a clutch would go through anyway. I imagine it would just become more of a problem as the clutch aged and the clearances really grew out, the old clutch actually had plenty of meat on it.
Mmmm.
2005 STI Liberty 5MT that's done 130,000kms. Complete with short shifter, full push type hydraulic clutch assembly, tail shaft and drive shafts. Oh, and an LSD.
This should cure my drive-train issues, seriously. And preps the car for an SG based dual range to go in at a later date.
Hmmm... Interesting move!
I've got a set of SG cases here if that's what you're after for the hydraulic clutch setup. Otherwise there's a mob in the Sydney area that are selling gearboxes for ~$200 plus postage without the centre diff. This could be the best way for you to build up a good box keeping the 1.59:1 low range and front LSD too. They do quote the wrong diff ratio IMO as they say they're all 4.44 ratio.
You'd better be careful mate, I can see this vehicle getting slammed again
It will be for the foreseeable future. I'm really not concerned about it's off-road capabilities at present. Plenty of passenger seats around if I need my offroad fix.NachaLuva wrote:Will you be driving this around for a while? Serious downgrade from a DR DCCD twin LSD drivetrain
The V6 STI suspension is still in the shed. First step is to get this car reliable, and enjoyable to drive again. At present it is a pig. From there focus on some other life goals. When it comes to looking at off-roading again I think something much more capable in total stock form will be the go. The philosphy with the next project car will be to achieve the capability mine has now with the least number of modifications. This one was more what would be the best with the most possible modifications. Getting this car back how it was when I bought it also makes it possible to road worthy for a sale.El_Freddo wrote:Hmmm... Interesting move!
I'm cool with selling the Lib. My emotional attachment is more with the concept and dream of what this car can do on and off the road than the car itself. If I think a SG (maybe even an SH) could do it better then I'll be excited to start another project.
I think that's the best option for you. Return to stock (H6) and sell, sell off you're parts, and get a SG/SH Foz. The 2.5 will be a bit of a downward move in HP/torque but will also make it more challengingVenom wrote:Getting this car back how it was when I bought it also makes it possible to road worthy for a sale.
Maybe an XT? Heaps of power upgrades and an auto already has a locking centre plus no need for LR. SH has VDC
Interesting. We're obviously cast from a different mould in some ways!
Why not go for an L series with your offroad gearbox powered by an EA81? Should be simple and fun yet still very capable. If I was still running the ea82 and didn't want to go EJ I'd be looking at dropping the ea81 in there.
But I guess you've got to look up if that's what you want to do. I'd go for the ej25 then drop your front LSD and low range in there. If you want simple swaps I've now got the 1.44:1 low range "in stock" atm.
Got a possible time frame to work this in? I'm just curious.
still seems worth trackng down what the issue is rather than just swapping the entire driveline and deleting the offroad capabilities. also why think about selling it and just keeping the concept mentally? Surely being able to drive the concept is better
The beauty of this single range swap is that the male/male driveshafts (Which i prefer for the stub delete) and clutch setup will work with an SG dual range and frees up my DCCD and Cusco for inspection and swap. The cusco actually has some end float with the stubs so it will be overall a better outcome anyway. So whether the car stays as an offroader or not it's a good intermediate step, and I can always sell the STI gear later on for pretty much what I paid.
There is a new suspect for the problem but I've speculated enough already and we won't know for sure until the gearbox is apart. May not be terminal, and the death of first and low range is predictable since I never hooked up the L/R oil feed to a pump. Both problems are very common and not restricted to a higher torque motor, although likely exacerbated by it.
Yeah 4.44. I think i'll be able to pretty much make up most of the ground from the drop to a 1.44 low range and gain the stronger SG gears... just an all round better gearbox. 4.44 should be less strain on the gears too. The 5th in this STI box is 0.730 so if I use it the revs will be lower than factory SG which should make up for the 4.44.
This STI gearbox is:
TY757VBCAB
1st: 3.166
2nd: 1.882
3rd: 1.296
4th: 0.972
5th: 0.738
Rev: 3.333
FD: 4.111
It has a 240mm clutch which has me a bit stumped right now. Going to have to bring the setup into the shop to get them to compare bits and pieces, and find a 240mm flywheel for a 5MT.
TY757VBCAB
1st: 3.166
2nd: 1.882
3rd: 1.296
4th: 0.972
5th: 0.738
Rev: 3.333
FD: 4.111
So a quick update, this epic shudder/jerking problem is still on-going. Imagine the drivetrain acting like a jackhammer, that's the best description for it.
Stock SF gearbox ended up going into the car. 1.447 and 4.11 for $300 from Jollys. This saw no change to the problem, but needed to be done anyway since 1st in the old gbox was howling. Stock tailshaft in, no change.
So the car spent some time at the mechanic, conclusion is it's the rear diff. Lots of backlash play. At this stage I'm not sure whats worn or why. The KAAZ is still functioning beautifully. It's not making any noise, so it seems unlikely to be crownwheel/pinion wear. Stock diff will go in soonish, most likely the KAAZ will go into the 06 Lib LSD housing with some new bearings and seals. Then the KAAZ and DCCD can go into the car further down the track.
