Subi Ebay sales
B00sting
Post by B00sting » Sat Sep 08, 2012 11:35 am
El_Freddo wrote:I shouldn't be looking on ebay.
blue 1989 targa brumby that ticks all the boxes and then some. Price isn't good in my book, if it came with engineering it'd be another thing.
actually that is a good price.
a lot of work done!
but you cant get it registered without a rwc which means engineering blah blah....
might be worth it.
-97 Landcruiser :D
Post by El_Freddo » Sun Sep 09, 2012 9:23 pm
B00sting wrote:actually that is a good price.
a lot of work done!
I could do all that work for less than that price including finding the right unit to begin with.
And this looks familiar
Brumby Kid
Post by Brumby Kid » Sun Sep 09, 2012 9:33 pm
El_Freddo wrote: And this looks familiar
so does the red brumby in the background :)
The Missus finally win revmax?
Dads Car: 02 Impreza WRX STi
rtcb65
Post by rtcb65 » Tue Sep 11, 2012 7:45 pm
One for the richer ones who wont to do the TURBO DIESEL 2.0L transplant.
http://www.ebay.com.au/itm/SUBARU-FORES ... 337becb27e
rtcb65
Redneck Rick.
Post by Silverbullet » Tue Sep 11, 2012 8:20 pm
Check out the front cover casting on that thing! :eek: And all that wiring :?
Post by TOONGA » Tue Sep 11, 2012 9:01 pm
That front cover hides the timing chain, a damn fine engine, Im biased my wifes forester is turbo diesel.
I would be interested to see if it could be run with just the computer.
Did anyone else notice the edis wheel on the back of the motor?
Post by Silverbullet » Tue Sep 11, 2012 9:27 pm
TOONGA wrote:\Did anyone else notice the edis wheel on the back of the motor?
I noticed it was odd, didn't click that it was the EDIS wheel though. So where does the flywheel go? :p
Post by El_Freddo » Tue Sep 11, 2012 9:38 pm
Silverbullet wrote:Check out the front cover casting on that thing! :eek: And all that wiring :?
That wiring is pretty similar to what you get yourself into when cutting down the EJ harness. I'm sure that harness would have more though.
TOONGA wrote:Did anyone else notice the edis wheel on the back of the motor?
Yeah but what's that acronym stand for?
Silverbullet wrote:I noticed it was odd, didn't click that it was the EDIS wheel though. So where does the flywheel go? :p
On the back of the crank where the bolt holes are, just like every other flywheel does ;)
Smokey
Post by Smokey » Wed Sep 12, 2012 1:09 pm
El_Freddo wrote:Yeah but what's that acronym stand for?
Electronic Distributorless Ignition System?
B00sting
Post by B00sting » Wed Sep 12, 2012 3:01 pm
rtcb65 wrote:One for the richer ones who wont to do the TURBO DIESEL 2.0L transplant.
what the hell seems cheap. last one i saw on ebay was 8500. :)
-97 Landcruiser :D
Post by TOONGA » Wed Sep 12, 2012 5:25 pm
B00sting wrote:what the hell seems cheap. last one i saw on ebay was 8500. :)
engine with computer.. no harness, key or immobilser. You would need an aftermarket miracle to get it to run or a direct transplant into another TD forester.
Post by Gannon » Wed Sep 12, 2012 6:09 pm
Its not an EDIS wheel!
1. EDIS generally refers to a computerised ignition control system that is separate to the fuel injection computer. Subaru has never had an EDIS system because they used the ECU to control their ignition timing in the 1987+ MPFI L Seres all all EJ's since. I suppose you could call all distributorless ignition systems EDIS, but nobody does. They are usually called 'coil on plug' or 'wasted spark' ignition.
2. Diesel engines dont have spark plugs or ignition coils so definitely no EDIS
The toothed wheel is simply the crankshaft timing/position wheel so the ECU can determine crank position. Probably mounted it on the back because the crank position sensor would be inaccessible on the front without first removing the massive chain cover.
nncoolg
Post by nncoolg » Wed Sep 26, 2012 3:09 pm
RX, maybe good value for parts...
http://www.ebay.com.au/itm/Subaru-RX-Tu ... 416b95ace7
RS intercooler setup & spare rad, spare pump:
http://www.ebay.com.au/itm/Subaru-Liber ... 43b3d649fb
# EA82 AWD 4EAT,
Party Machine ...
Post by Bantum » Wed Sep 26, 2012 5:47 pm
A bit of a doof doof machine for you ... :D
http://www.ebay.com.au/itm/Subaru-Fiori ... 2a226d0125
Also a nice looking Brumby :
http://www.ebay.com.au/itm/Subaru-Brumb ... 20cb263f20
Another interesting 'Camo' Impreza :
http://www.ebay.com.au/itm/Subaru-WRX-W ... 2ec1fc11ed
Post by TOONGA » Thu Oct 04, 2012 6:54 pm
value? buy of the month for some one in SA
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... escription
555Ron
Post by 555Ron » Thu Oct 04, 2012 7:00 pm
TOONGA wrote:value? buy of the month for some one in SA
I'd like it but I am in NSW. It was on last week for $0.01 but there were no bids.
Post by TOONGA » Sat Oct 06, 2012 6:01 pm
Anyone need and ignition relay and a couple of fuel relays?
http://www.ebay.com.au/itm/Subaru-Impre ... 3f1cf67e2c
Post by El_Freddo » Sat Oct 13, 2012 9:41 pm
22B on fleabay going cheap... for a 22B! Only 31,000km!
Venom
Post by Venom » Sun Oct 14, 2012 8:08 pm
Got some of my own ebay sales up at the moment.
EA81 dual carb setup, with factory air filter:
http://www.ebay.com.au/itm/170924771277 ... 1555.l2649
Viscous LSD R160
http://www.ebay.com.au/itm/170924776485 ... 1555.l2649
L series dual range box
Post by TOONGA » Wed Oct 17, 2012 4:01 pm
new EA81 oil pump even with shipping a bargain
http://www.ebay.com.au/itm/Subaru-Brat- ... 33701a76d7
