My Touring Wagon EJ25 build, Part 2
Post by guyph_01 » Wed May 02, 2012 8:34 pm
Ok got some work done and only had the time to install one shock:)
Turns out its way longer that expected and i has to completely remove the lift bracket.
The Left side with the new shock:)
The right side with the std Shock
I'll take more pics when i fit the second one tomorrow:)
Post by guyph_01 » Wed May 02, 2012 8:57 pm
Some pic when Wagonman and Dann came home for a visit:)
Post by guyph_01 » Thu May 03, 2012 1:45 pm
Ok so i finally got them in this morning.
Really happy with the height:) I now have 62mm between the wheel and whee arch and 322mm from the ground to my diff plate. Only thing i'm not sure is if they will last. Again, Only one way to find out:p
Now the next step is to figure out the bump stops extension and with the new gearbox i'll be step to go camping/offroad. its been SO long...
Anyway some pics...
Lol at the bird shit on the glass, need to give her a wash...
Post by Alex » Thu May 03, 2012 1:55 pm
geez id be careful where you drive it....cop bait bigtime.
Post by guyph_01 » Thu May 03, 2012 2:01 pm
Don't say things like this!!!!!!!!!!!!! Put the spell on me.... Touching wood, touching wood....
But all in all its got a two inch lift kit and stock (from different cars) suspension parts. And my young days of hooning around are over. Only thing left to do is get rid of the canon as that will attack them...
Post by Alex » Thu May 03, 2012 2:03 pm
haha im not trying to bag out all your hard work (i can appreciate it) but most lifted l-series' still look in proportion and cops dont really know what theyre looking at...yours on the other hand.....
still a brilliant effort though :)
taza
Post by taza » Thu May 03, 2012 2:18 pm
Alex wrote:haha im not trying to bag out all your hard work (i can appreciate it) but most lifted l-series' still look in proportion and cops dont really know what theyre looking at...yours on the other hand.....
Agreed, Looks bloody amazing.
You should get a photo of it next to my stock L-Series for some height comparison pics. lol
I think once the cannon is gone (removed or ripped off :rolleyes:) then it shouldn't be a cop magnet. They would probably just think its a normal 4WD.
Your over the hooning stage so thats not an issue.... unlike myself ( my L-series racing a mates Outback on the freeway lastnight :rolleyes:)
Post by El_Freddo » Thu May 03, 2012 9:49 pm
So the end result was due to the silvia (exact model was??) strut and what spring have you used in the end?
You've got me thinking now... maybe.
Looking good though mate, it still rides well? What sort of angle do you have on the CV's and have you got the rear bar fitted with spare and full jerry can yet? That'll bring it down a little bit ;) Not a bad thing!
Post by guyph_01 » Thu May 03, 2012 10:19 pm
Not sure on the year model. All i know its from a Silvia lol.
I'd still go with the screw adjustable type ones if they were cheaper or if i can get a cheap set. I've used the normal L series king springs. Not hard at all. Same to what i had with the civc springs. Very happy with it. Hopefully they won't fail.
Put yeah if you have 3 inch strut lift and you get the screw type Silvia rear Coilovers than you can use the civc springs.
I know between the different model skylines and siliva's you can have different hight ones. I'll try and figure out from what sylvia mine came from.
cv angle is more than before. Not sure how long mine are gonna last. The rear cv's are the only thing that hasn't been changed or replaced since i got the car 4-5years ago:)
vincentvega
Post by vincentvega » Fri May 04, 2012 4:37 pm
hard to tell in those pics but looks like those struts have integral bump stops?
you may not need to bother extending the factory ones.
Post by guyph_01 » Fri May 04, 2012 5:21 pm
yeah i've placed integral bump stops from the L series shocks in those ones but i just want to be 200% sure:)
d_generate
Post by d_generate » Fri May 04, 2012 5:36 pm
:idea: Is that the hose clamp of safety I see sitting just under the spring base?
Post by guyph_01 » Fri May 04, 2012 6:51 pm
d_generate wrote::idea: Is that the hose clamp of safety I see sitting just under the spring base?
Lol, yeah after what happened last time i was out i figured it won't hurt if i just put one on each side. Just in case. Lol
Post by RSR 555 » Thu May 10, 2012 1:38 am
guyph_01 wrote:yeah i've placed integral bump stops from the L series shocks in those ones but i just want to be 200% sure:)
Can not hurt to be over protected ;) last thing I want to hear is 'PAUL.. HELP !!' especially when I'm relaxing in the cool beach water drinking CCs
Post by guyph_01 » Thu May 10, 2012 4:22 am
RSR 555 wrote:Can not hurt to be over protected ;) last thing I want to hear is 'PAUL.. HELP !!' especially when I'm relaxing in the cool beach water drinking CCs
Lol :p
d_generate
Post by d_generate » Thu May 10, 2012 3:34 pm
RSR 555 wrote:Can not hurt to be over protected ;) last thing I want to hear is 'PAUL.. HELP !!' especially when I'm relaxing in the cool beach water drinking CCs AVOIDING THE BEE'S AND FLIES.
Fixed
I'd be splitting a bit of pipe and using exhaust clamps to hold it in place, or maybe carrying it with you as a stronger fix.
Post by guyph_01 » Thu May 10, 2012 4:12 pm
Ok so the bar is finally done:)
Really happy with it...
Ohhhhh and i finally succumbed to the pressure and had it taken off:)
Nan but yeah it was time and its much quieter now. Less of a cop bait in a way.
purp
Post by purp » Thu May 10, 2012 4:32 pm
Looks most excellent.
What is your reverse light output like, looks like the hinges on the bar might block them a little? Or is the work light on the roof wired into them?
thunder039
Post by thunder039 » Thu May 10, 2012 4:58 pm
cars looks great :D, good to see that you got rid of that huge muffler:wink:.
also i looked through the thread and could find it, what size are thoes tires? and what tires are they? thanks
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
Post by guyph_01 » Thu May 10, 2012 6:55 pm
purp wrote:Looks most excellent.
Yeah its kinda blocked but i have the three little lights on the bar, one reverse, one brake and one signal light to compensate.
thunder039 wrote:cars looks great :D, good to see that you got rid of that huge muffler:wink:.
They are 215/70/16 and they are Sonny cheap Chinese tyres. They were $200 for 4 as new:p
Return to “Guyph”
