I own a vortex :)
Post by TOONGA » Thu Apr 24, 2014 8:01 pm
RSR 555 wrote:Stick with Aluminium
You spring the 300 + dollars for the custom made Aluminium radiator and I will. :)
The Aluminium ones on Ebay have plastic end tanks and as that radiator dosen't have a filler cap I wouldn't be able to use one of them without adding a pressurised reservoir.
Post by RSR 555 » Thu Apr 24, 2014 8:15 pm
TOONGA wrote:You spring the 300 + dollars for the custom made Aluminium radiator and I will. :)
Don't need custom, just buy a XT6 aluminium one
Post by TOONGA » Thu Apr 24, 2014 8:29 pm
RSR 555 wrote:Don't need custom, just buy a XT6 aluminium one
It would be cheaper to buy a custom made one :)
Post by RSR 555 » Thu Apr 24, 2014 8:47 pm
TOONGA wrote:It would be cheaper to buy a custom made one :)
At least a custom made one would last longer that the car if you keep replacing your coolant
Post by TOONGA » Thu Apr 24, 2014 8:50 pm
Does sea water work as coolant?
And we both know that Jet car will eventually succumb to its rust :(
Post by RSR 555 » Thu Apr 24, 2014 9:04 pm
TOONGA wrote:Does sea water work as coolant?
Sea water is one of the best coolants for heat transfer.. so you should use it :rolleyes:
Unfortunately Jetcar and Honeycomb are just as crippled and bad shape as their owners ;)
Post by TOONGA » Sat Sep 13, 2014 9:38 pm
So why is my vortex up on ramps over a pit?
With Dougs much appreciated help and patience, we were going to put these headers on to make a custom exhaust but the didn't clear the crossmember or the bottom hose.
So out came the reciprocating saw.
from this
to this
Those factory headers never saw it coming :)
repairing a crack
tacking pipes together
Continued next post
Post by TOONGA » Sat Sep 13, 2014 9:41 pm
more tacking
Doug welding while I act as the vice
The finished product
Installed and running like a dream
Sounds great, but sadly the video I took this afternoon was too distorted to use.
Post by NachaLuva » Sun Sep 14, 2014 7:46 am
TOONGA wrote: Image
Now thats a UEL! :twisted:
Love the badge lol :cool:
Post by TOONGA » Sun Sep 14, 2014 8:32 am
NachaLuva wrote:Now thats a UEL! :twisted:
Yep and Doug did a great job I owe him big time for this.
NachaLuva wrote: Love the badge lol :cool:
Sadly that was the only part of the turbo headers that woulld fit :)
Subydoug
Post by Subydoug » Sun Sep 14, 2014 10:31 am
No worries mate, she sounded sweeeeeeeeet! To anyone thinking of doing this I would suggest a second pair of std headers. We ended up cutting the flange off of one and spinning it 180 degrees. I should make one for the wagon, but I think Il use new stainless, just so I can tig it.
Doug
Post by TOONGA » Sun Sep 14, 2014 6:26 pm
I would suggest either the second set of headers or as Doug said when we were making the headers, cut the bends off the factory headers and mate the two shorter tubes to the new pipes.
Post by NachaLuva » Mon Sep 15, 2014 12:41 pm
Can you post a side on pic of the headers so we can see how the short side blends in?
Really impressed with this. It would give an awesome boxer rumble :twisted:
Have you noticed any change in engine performance?
Post by TOONGA » Mon Sep 15, 2014 10:01 pm
Ok short side isn't pretty but is functional
As for change in performance it sounds faster :)
I seem to be driving a bit more like a yobbo as it sounds great.
Still no usable video sorry.
I spent this afternoon chasing a fuel pump relay gremlin, only to have the problem solved by changing relays around and tugging on a couple of wires.
Very professional :rolleyes:
Post by NachaLuva » Tue Sep 16, 2014 12:43 pm
May not be pretty but looks strong & more importantly no leaks! :D
Post by TOONGA » Tue Sep 16, 2014 7:17 pm
Yep Doug did a great job.
I'm thinking the engine may actually be more responsive at low revs now. I have less problems with my heavy duty clutch wanting to argue with the flywheel, when I have to ride the clitch on a hilly intersection.
Post by TOONGA » Sun Oct 19, 2014 9:13 am
I'm having a problem with my EJ22 it has an intermittent start fault cold or hot
the engine will crank and nothing, then when I crank it again it backfires, then when I crank it runs like it has flooded. (which it has)
I've changed ...
The coolant temp sender (new)
the knock sensor (new)
the crank angle sensor (working second hand unit)
the cam angle sensor (working second hand unit)
the igniter (working second hand unit)
the coil pack (working second hand unit)
the afm (working second hand unit)
the O2 sensor (working second hand unit)
the ECU (working second hand unit) both have been reset
the ignition relay (working second hand unit) and the franken relay
And my car still does it :(
I'm going to check to see if the timing belt is lined up tomorrow if I have a rain free period. (it is the only thing I can think of)
Venom
Post by Venom » Sun Oct 19, 2014 9:37 am
Yeah I was going to say maybe the cam sprocket has slipped a few teeth on the belt.
Post by TOONGA » Sun Oct 19, 2014 11:56 am
So I just had a total WTF moment... I pulled the plug lead on number 1 and put a screwdriver in to check for spark ... nothing on crank, so I moved the screwdriver and I tried again I got spark and the car ran on the other 3 cylinders.
I tried to put the lead back on but the engine stalled before I could get it back to the plug. Once again when cranking nothing, the car won't run and the bolts holding the cam covers on are spinning due to the plastic breaking around the lugs. I have given up due to rain and total frustration.
It is definitely not fuel as the plugs are drowned somewhere in the electrical/spark department there is a problem that I cannot diagnose.
Subydoug
Post by Subydoug » Sun Oct 19, 2014 3:44 pm
Check your ground strap. Also check the resistance thru the lead while manipulating it. IF it changes at all, throw it in the bin.
Doug
