My GT2 wagon
Chris_Rogers
Post by Chris_Rogers » Sat Jan 05, 2008 10:41 pm
code 66....
no idea why. happened on a full throttle overtaking run and hit a fuel cut doing it. need a service manual for this thing.
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
Chris_Rogers
Post by Chris_Rogers » Sat Jan 05, 2008 10:42 pm
Alex wrote:im so jealous of you right now!
who .... ... me??
Audio Express
Chris_Rogers
Post by Chris_Rogers » Sat Jan 05, 2008 10:47 pm
D3V1L wrote:charcoal canister shouldnt effect anything or even hint about causing any noises.......might caus a tad of surging but this box of yours should eliminate that...and yes...turbo whine is different..lmao....any way u can describe it any better? or is it just simply that...obviously i cant really offer any advice at all unless i hear it so sorry i cant be of any more help...
dave
hard to describe really. its a loud throttle based whine that goes away when the second turbo comes in. tried to record it but the sound doesn't really come through.
need a second car to (legacy GT) to compare to. boost box is getting swapped back the thing is too laggy now. think the one I have in there now is a later one as it is plumbed a bit differently.
still need to set the throttle up as well - code 24 pops up if I back off too quickly. think its due to the fact that 0.480v is meant to be the low limit and its dropping lower than that and flagging the code.
other than that its one very wild ride once it gets moving.
Audio Express
schultzie
Post by schultzie » Thu Jan 10, 2008 7:43 pm
could that be air escaping through the BOV till it closes? i know mine sounds a bit like a whistle until i come on boost
L-series Ea82t, WAIC+BOV 1Bar, 15's, 5sp dr, WOLF3D V4+, =D
Post by Gannon » Thu Jan 10, 2008 8:09 pm
It might be one of the crossover valves not shut fully and letting just enough air through to make a whistle.
Chris_Rogers
Post by Chris_Rogers » Fri Jan 11, 2008 7:46 am
unsure. swapped boost box thinking one of them was not working properly.
needs a VAC pump though. there is not enough VAC to run the heater and the engine as well.
still fiddling with this 'noise' BOV's (2) are next at $180 a shot.
Audio Express
schultzie
Post by schultzie » Fri Jan 11, 2008 6:34 pm
make a vacume cannister out of soem 100mm pipe and 150 long and get some one way valves fromn the aquarium and make a vacume canister from it all....
Chris_Rogers
Post by Chris_Rogers » Fri Jan 11, 2008 8:54 pm
mine has a OE one in the front left guard. probelm I have is it runs out of vac after a long climb (IE the car is ALWAYS on boost and the 5 solenoids in the boost box are running.) and when I nail it I get code 66 (TT fault.) I'm after an actual pump I can kick on when I plant the foot so I have a constant vac supply. I have the switch in place on the accelerator pedal - may as well use it.
good idea though. TT is a VERY steep learning curve for me (the fault codes anyway - the rest makes sense.)
Audio Express
Post by El_Freddo » Wed Oct 29, 2008 10:52 am
Chris, what's the update on this? I've heard a rumor that you may have sold it? True/false?
I was hoping to see a video of this thing in action!
Chris_Rogers
Post by Chris_Rogers » Wed Oct 29, 2008 11:33 am
El_Freddo wrote:Chris, what's the update on this? I've heard a rumor that you may have sold it? True/false?
nope. still have it . broke gearbox - no 2nd gear so it sits until I get $5k to fix the box properly.
Audio Express
vincentvega
Post by vincentvega » Wed Oct 29, 2008 11:53 am
5K ??????
mate you can get a good rebuild done for a lot less than that.
Fang
Post by Fang » Wed Oct 29, 2008 11:57 am
Chris_Rogers wrote:nope. still have it . broke gearbox - no 2nd gear so it sits until I get $5k to fix the box properly.
I'm responsible for this rumor Chris - I thought you said you were selling it? I got that indication from an email from you at the start of the year?
Post by El_Freddo » Wed Oct 29, 2008 12:17 pm
$5k?! That's insane!
Glad to hear you've still got her... Yes it was Fang who said it but also said that he couldn't nail it 100% (not that I was going to mention you mate). So I thought I'd dig up the post and see what was going on. Plus its been so long since an update on this project!
Sorry to hear about the gearbox, Alex (Keffa) could suggest some quick gearbox change tips for you :twisted:
Hope its all sorted after you get the gearbox set the way you want it. This wagon really is a piece of work!
MORE PICS PLEASE!!!
bluesteel
Post by bluesteel » Wed Oct 29, 2008 2:25 pm
5k equals 6 speed or ppg... whats it gonna be?
i highly reccomend the 6 speed (have had ppg straight cuts too)
Chris_Rogers
Post by Chris_Rogers » Wed Oct 29, 2008 5:08 pm
Perfourmance use a fellow out coorparoo way (he's responsble for the blue 9 sec brumby.) that said worst case was $5k to totally rebuild it from scratch with a bit of a stall converter as well. I'm going on worst case.
would love a 6 spd but prefer auto in the thing. its easier to drive.
Audio Express
vincentvega
Post by vincentvega » Wed Oct 29, 2008 5:46 pm
my full rebuild cost me 2650 including valve body mods for increased line pressure. That was the converter opened up and serviced and everything.
You aren't building a 9sec drag racer! you jsut need your auto freshened up.
pm me for details if you like.
Chris_Rogers
Post by Chris_Rogers » Wed Oct 29, 2008 6:00 pm
will do. bob grant automatics are te people he uses.
Audio Express
wagonist
Post by wagonist » Fri Nov 28, 2008 2:25 pm
I haven't read this thread for a while.
I wish I'd known about those thin fans, that "may" have worked on my car, but I've given up & am returning it to stock(ish) to sell off.
anyone want a WRX engine with factory loom to suit an L Series?:p
And a completely rust free shell:p;)
anyway, did you end up getting the water temp guage fixed to read correctly?
To do mine, I removed the water crossover pipe from the engine (requires removing the inlet manifold too), removed the EJ sensor, welded up the hole & built it up more (the L sensor is physically bigger), then redrilled & tapped the hole to suit.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
Chris_Rogers
Post by Chris_Rogers » Fri Dec 12, 2008 7:58 pm
I haven't played with that yet. it reads a 1/4 low so I mentally adjust for that.
still saving for the box rebuild.
Audio Express
Chris_Rogers
Post by Chris_Rogers » Mon Oct 05, 2009 9:24 pm
finally found the DIN width radio for this car. its taken 3 years to find it!!
now its time to play with the audio on it.
Audio Express
