Bill's little Superu
cool banana
Post by cool banana » Thu May 01, 2008 2:42 pm
Again..Nice Car!
The front towing point...what type is it and how have you mounted it? Any close ups and info would be greatly appreciated.
cheers
Martin
Superu
Lift kit installed
Post by Superu » Sun Apr 26, 2009 2:45 am
more to come...
05 Subaru Outback
"99% of being smart is knowing what you're dumb at..."
The Superu
Outback bloke
Post by Outback bloke » Sun Apr 26, 2009 3:28 am
EE710533992AU AUSTRALIA SLOVENIA Your item arrived at the international processing centre in SLOVENIA - LJUBLJANA at 16:11 on 18 Jul 2008, and is awaiting clearance for delivery processing.
Yes, you read that right! My lift kit took a detour to Slovenia!!! :-)
It is no wonder things get lost at times. The car is looking good. Bigger tyres now maybe?
Superu
Post by Superu » Sun Apr 26, 2009 6:53 am
Thanks!
I just put a new set of Yokohama Geolandar AT/S on today. 215/65/16. They are bit bigger than stock, but leave me enough room between the tire and the Rally Armor mud flaps so snow and slush won't get jammed up in there too often.
:D
05 Subaru Outback
The Superu
riksta
Post by riksta » Sun Apr 26, 2009 10:09 pm
Looking real good now mate, with the lift kit in it makes the car look like a off roader,
it just looks a lot better now that it's sitting up a bit, the hole car looks BIGGER.
Nice job mate, looks good.
Rik.
Superu
More pics and details.
Post by Superu » Sun May 03, 2009 9:57 am
Finally getting a few minutes to post up some additional pics.
One of four rear carrier spacers.
The installation starts with a trolley jack under the rear carrier. Loosening the carrier bolts and lowering the carrier about 3 inches. Spacers go in, bolts go in hand tight, rear A-arms are loosened, spacers installed, bolts snugged up. Struts out, spacers on.
Gearbox spacers go in next. Same process, lower with jack, install spacers, bolts in, back up.
Front installation is pretty much the same as the rear.
It helps to have friends around to lend a hand with putting things back together.
Or in the case of the steering coupler, pulling them apart!
Of course, it helps to keep a positive attitude and a smile on your face!
Issues encountered were a stripped bolt hole, four rear carriers bolts that had to be cut down and a steering coupler that had to be cut and re-machined.
Results with 1" suspension lift via King Springs and 2" body lift via Ausubaru spacer lift:
Thanks to all who gave their time, support, encouragement, took some of these photos and provided advice along the way. Will keep everyone updated on the next adventure we take with the Superu!
05 Subaru Outback
The Superu
Post by AndrewT » Sun May 03, 2009 3:34 pm
Certainly does look better now! What exactly was the issue with the steering coupler? Seems very strange!
riksta
Post by riksta » Sun May 03, 2009 7:17 pm
looking good there mate, how is the ride now with the lift kit in? You mite find it a bit of a harder harder ride now, but to much I hope.
Rik.
Post by AlpineRaven » Sun May 03, 2009 8:11 pm
wow that looks great there... it'll be a head turner!
Post by El_Freddo » Sun May 03, 2009 10:59 pm
That is one tough looking Outback, more so now that its got the lift!
Keep up the good work, can't wait to hear what you think of the lift and see the pics of your next outting!
Superu
Post by Superu » Tue May 05, 2009 5:43 am
AndrewT wrote:Certainly does look better now! What exactly was the issue with the steering coupler? Seems very strange!
Steering coupler was too long. Not sure if there was a difference between right hand and left hand drive Outbacks, but there was no way to make it fit without cutting it down and welding it back together. It's good now! ;)
05 Subaru Outback
The Superu
Return to “Photo Gallery”
