Ellies cooling saga .
Post by El_Freddo » Sat Oct 20, 2007 12:10 am
Well i spoke to the radiator guy. He reckons an MY radiator, manual, would be the go. Its 6mm taller and a little shorter but has two cores. The outlet pipe would be sourced from a hilux or hiace radiator to retain the original radiator hoses...
Hope this helps some.
PS my rad will keep me going, but is pretty much cactus
discopotato03
Post by discopotato03 » Sat Oct 20, 2007 7:34 am
If you see the MY and L rad side by side you'll find that its the mounting straps top and bottom that are taller/wider/bulkier . The MY bottom strap has a different mounting system to the L ie holes instead pins to fit the body .
Also the MY core has slightly larger and slightly fewer tubes and less gills (fins) per inch than a later or L type core .
More next week , cheers A .
discopotato03
Post by discopotato03 » Tue Oct 23, 2007 5:53 pm
Latest update , we looked again and could not find any Impreza core of the same dimensions as an L core . After looking through catalogs of about 300 radiators I gave up trying to find a core that would fit L radiator tanks . The problem is that the core height has nothing to do with the length of the header plates so trying to find a suitable core is virtually impossible . The costs involved in doing a one off copper/brass or aluminium radiator are not justifiable to me anyway .
With what I know know if I was doing a high powered EJ conversion I would modify the top of the radiator support panel and fit a suitable vertical tube radiator . The trouble with the L series is that the opening is wide but not too tall and horizontal tanks take up the valuble height in a vertical tube radiator .
My solution will be to fit a complete new Koyo radiator as they are supposed to be to OEM standards which are better than locally made items . When it goes in I've been asked to take the old one back so it can be opened up and we all reckon its half or more blocked .
In a perfect world we are supposed to change our coolant and flush the cooling system on a 12 monthly/20 000 km basis to help stop sludging radiators etc up . Also the coolant can "go off" and do more harm than good to the system .
More later , A .
discopotato03
Post by discopotato03 » Fri Nov 09, 2007 12:23 pm
Latest update , after new std Koyo rad I fitted a Davies Craig thermo switch to the water pumps inlet tube ie where the post rad hose connects to the engine . I did it on this side to control the radiator outlet temperature rater than its inlet temp . The variable switch gadget controls a relay that when closed connects the wires that used to plug into the radiators thermo switch . This means no mods to the original factory wiring and the plug can be refitted to the rads thermo switch if any need arose .
Ellie now runs a bit cool if anything because now that I can control the rads water temp the 160F thermostat regulates a bit low and the oil temp is down and this shows as higher consumption ie a bit over 500 instead of nearly 600 to the tank . Oil temp is in the mid 70's C . The next step is to refit the 170F thermostat and see how it pans out oil temp and consumption wise . At a later stage I want to remove the engine fan and replace it with something electric in front of the rad , Gee said he likes the Bosch one from old S series Mercs and that would be cheaper than a new Davies Craig . May even troll the wreackers for a 2nd hand D Crg .
Cheers A .
Post by steptoe » Sat Nov 10, 2007 11:07 am
can i be a pain and ask...is that nearly 600km to 60litre tank in the EA82 Turbo RX sedan ??
I did not think op temp could make such a hUge difference in fuel consumption !
discopotato03
Post by discopotato03 » Sat Nov 10, 2007 11:27 am
Yes thats what the Odo reads . The consumption loss would almost certainly be due to cooler oil having more drag I reckon (oil sheer drag) . Mid 70's deg C (oil temp) is a bit low for normal driving in the suburbs . If it makes any difference the fuel I used until recently was Shell V power - not the 100 oct Racing one . Trying the Shell E10 ATM .
As for my driving style I short shift most things I drive and let the torque do the work . I believe slightly wider throttle openings at not a lot of revs increases an engines volumetric efficiency by raising its dynamic or effective compression ratio . EA's have pretty agricultural heads but they can breathe ok at lowish revs provided the throttle is open far enough not to limit flow too much . EA82T's have a really patheticly low 7.7:1 static compression ratio so they need all the help they can get . The header pipe at the "T" joint really is RS and I would expect to see a noticable consumption rise if fixed properly .
Anyhow a bit higher water temp should raise the oil temp and bypassing the throttlebodys water heating passage may very slightly drop the charge temp .
Cheers A .
