Water Crossings, How deep will a L series with 2" lift
wagonist
Post by wagonist » Thu Dec 08, 2005 2:28 pm
Air into the intake will not stall the motor before it reaches the motor.
Personally, I don't know why some people go to all the trouble sometimes.
I've forded streams with water half way up the windscreen with lift kit, 14's, but no tube extensions for diff or gearbox (maybe that's why the centre diff went in the box though :oops: ), no glove over dizzy.
If you can create the right bow wave & if possible have the left side of the car (the distributor side) downsteam, then you can go pretty deep.
Ron was a pretty cautious guy but kept his cars in good nick though too.
And whatever you do, DO NOT seal up the timing belt covers. You'll simply overheat them. Water can't get from them into the motor unless your seals are stuffed.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
smoov
Post by smoov » Thu Dec 08, 2005 5:20 pm
tim_81coupe wrote:
smoov wrote: Also another issue that isnt covered are wheel bearings. Do a few water crossings, and within a few months, you can kiss your bearings goodbye. Replace them with sealed ones. As to the part numbers, perhaps someone would be as so kind to quote numbers. There is a thread floating around here with the info you need on these.
Nerd to the rescue! The normal units are a 6207 bearing, 35 ID, 72 OD, 17mm wide. To get a sealed one, use the number 6207ZZ. This bearing is entirely metal cased and pre-lubricated. However it costs about twice as much as a standard bearing, but I'd say its worth it if you want to come into contact with water on a regular basis.
Thanks for that tim. is that the numer for the fronts or rears? Would you happen to have the numbers for the others too?
I think I may have to force myself to replace my 3 month old bearings soon :twisted: :lol:
1998 Subaru Legacy GTB
tim_81coupe
Post by tim_81coupe » Thu Dec 08, 2005 7:39 pm
That's for the fronts. I'll check the rears out tomorrow.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
smoov
Post by smoov » Thu Dec 08, 2005 8:26 pm
cheers mate 8)
FISH_Stalker
Post by FISH_Stalker » Fri Dec 09, 2005 8:14 am
I have been threw a river in my 84 wagon with no Lift. water was well over the front bumper, Just over the bonnet. All I had was a tarp covering the front of it. I was suprised it didnt stall.
PS, i have cut the front and the back of the cleaner box out, for a little more performance. After we crossed I had a look at the filter and it was pretty wet :)
wagonist
Post by wagonist » Fri Dec 09, 2005 10:03 am
Cars with the EA81 motor have a lot more problems because the distributor is on the front of the motor just behind the radiator. Whereas the L series is on the back instead.
Current rides:
Previous rides:
PeeJay
Post by PeeJay » Fri Dec 09, 2005 1:09 pm
I never had problems with the distributor while I had the rubber seal working in my EA81.
I did have major problems with wet air filters! The filter was the only thing keeping the water out!
Fang
Post by Fang » Fri Dec 09, 2005 1:15 pm
My problem too Peejay. They dont tend to like drinks of water I have found :oops:
I am going to revert back to the the original air cleaner - will have to do some chopping and welding for the Weber
SuBaRiNo
Post by SuBaRiNo » Sat Dec 10, 2005 2:27 pm
Im not going to coment on this too much... my last few river/swamp crossings have cost me well ober $3000 in damages. Im still trying to get the smell out of the carpets and seats.
Dave
tim_81coupe
Post by tim_81coupe » Sat Dec 10, 2005 3:57 pm
I just realised this morning, smoov, that I've given you MY part numbers! Not sure if I can get the numbers for sealed L series fronts, they're a different type of bearing aren't they?
The rears are a single piece unit that look sealed already. Only way I can think of immediately to make them more water-safe would be to use silicone hub seals.
I need to research this a bit more I think.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
aspro
Post by aspro » Sat Dec 10, 2005 10:38 pm
Tim you are a legend, let us know when you have the numbers and i will place an order :)
Guest
Post by Guest » Sat Dec 10, 2005 11:56 pm
Aren't the fronts the same on both L and MY?
PeeJay
Post by PeeJay » Sun Dec 11, 2005 11:34 am
I sure hope so because I have a set of Nachi 6207s here for my old car that I never ended up using.
aspro
Post by aspro » Mon Dec 12, 2005 10:43 pm
ASPRO your pics did not work.
Sorry about that Kerry :)heres a link to my webshot folder
http://community.webshots.com/user/aspro109
Hope you enjoy :)
Have used a hostng service before but have lost the details
Ben
Post by Ben » Tue Dec 13, 2005 7:37 am
MUDRAT wrote:Aren't the fronts the same on both L and MY?
Yeah, MY and L have the same front bearings (use 62072RS as they are cheaper than the steel sealed ZZ's) but the oil seal is different between the two models. If you are running sealed bearings just use the old oil seals anyway.
You can't get sealed rears as they are tapered bearings.
Please watch before posting!
tim_81coupe
Post by tim_81coupe » Tue Dec 13, 2005 9:30 am
LOL. That's what I found out yesterday and forgot to post last night :P
I can't help at all with the rears.
I don't know about using the 62072RS bearings in a wheel bearing environment, there's a lot of heat and pressure and I have seen bearings in other environments pop those little rubber seals out, which is why I recommended the ZZ bearing.
But, that said the 2RS will probably be up to the job. I just feel the ZZ is the safer choice.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
