CV Shafts,.. what do you buy
Post by El_Freddo » Sat Jun 09, 2007 11:45 am
Fang wrote:From my experience, If not buying the entire shaft, RX inners will not be enough. I have travelled this road. I had the RX cups ready to put into my L for my gearbox conversion (25 spline) - but the RX cups were too big too fit onto the ball of the standard L shaft. It must be my mistake about the outers however (apologies) - but unless I was given the wrong ones to start with - RX cups will not fit on the standard ball. I think Postie is also an expert on CVs now after his conversion.
I think fang means that the ball cage for the RX is larger than that of MPFI and stock cups. If you get the MPFI cups (with the 25 splines) you can just change your cups from the standard ones as the cage fits in these.
The outer CV (on the hub side) is whats the same on all models - i think this is what Mechawagon means.
Correct me if i'm wrong.
Cross communications, what would the world be like without them eh?
Fang
Post by Fang » Sat Jun 09, 2007 11:50 am
El_Freddo wrote:I think fang means that the ball cage for the RX is larger than that of MPFI and stock cups. If you get the MPFI cups (with the 25 splines) you can just change your cups from the standard ones as the cage fits in these.
That sounds correct as far as my experieces - thanks!
Phizinza
Post by Phizinza » Tue Jun 12, 2007 11:21 am
I go to u-pull it. Look for ones with good boots. Pull 'em in under 20mins. Pay $25. Then through them in my ute. It's a quick job once you know what your doing. And for $25, I don't even care if they only last 15,000kms. Sometimes it pays to pull the boots back and through some more moly grease in there though.
redskin
Post by redskin » Tue Jun 12, 2007 11:40 pm
The cv's from Kempsey are crap, l've broken them and had bearings disintergrate in them and nearly all have done this under 12 months, try to get him to replace them without an arguement, anyway l got sick of doing this so l bought a set of Turner's from Andrew Medieke's on Hastings River Drive and have not had a problem since. They were about $200 c/o and come with a two year warrenty, l've had mine for about that, no noise, no cracks in boots, no grease splattered all over the engine bay. Granted they may be a bit more and mine are the standard 23 spline, but they have been pushing my turbo around now for 15 months without complaint.
Redskin
89 Brumby
EA-81T.
Post by Gannon » Wed Jun 13, 2007 5:28 pm
Mmmm, so im lookin at either REPCO or anything but kempsey ones.
Repco ones are made by a company called 'national parts' i believe.
Might give em a go. they have a 2yr warranty i think
Redskin, i might drop in on friday maybe, give ya a look at my conversion.
aspro
Post by aspro » Wed Jun 13, 2007 11:12 pm
I have always purchased cv's from the Australian cv joint centre, originally in NSW (Rydalmere)10yrs ago. They are distributed nationally with outlets in Slacks creek QLD and Balcatta Perth.
It has been ages since i purchased so who knows what they are worth now, but I can tell you it was a quality product, great warranty and they lasted.. had a tour of their factory and all. Very impressed
18 South St, Rydalmere, NSW 2116 Phone:(02) 9638 0985Fax:(02) 9638 5252
give them a call and find out who stocks them closest to you.
Aspro
redskin
Post by redskin » Wed Jun 13, 2007 11:14 pm
No problem Gannon, l will be in all day but please ring first, l am really keen to see what you've done to the beast.
Redskin
89 Brumby
EA-81T.
