Clutch / cable or something else?
SUBYDAZZ
Post by SUBYDAZZ » Thu Jun 07, 2007 11:06 pm
I have what appears to be part of an outer race of something come out in the oil...
SUBYDAZZ
Matatak
Post by Matatak » Thu Jun 07, 2007 11:17 pm
sounds liek u need to go get another g/box
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
SUBYDAZZ
Post by SUBYDAZZ » Thu Jun 07, 2007 11:42 pm
Though curiously the shifting problems appear to have ended. All I have really done is change the clutch (which appeared to have a bit of meat still left on it) for a PBR one (was cheap and in stock when I needed one).
Took it for a drive to adjust my clutch and hill-holder cables and I don't appear to be having any issues - yet. It seems quieter now the spigot bearing and thrust bearing have been changed too, the other ones were not the best.
Have filtered the gearbox oil with my not-yet-patented system of using microfibre garmet rags. Have refilled and will re-drain to flush out any more metal stuff and put some fresh oil in tomorrow, shall do the rear diff also.
Last time I pulled lots of metal bits out of a gearbox was my last white wagon (L-Series) and I thought that was stuffed (awful noises when it happened and a lot of metal chunks came out), but last I saw it the new owner had put on 70,000km with the same box from memory. Strongly suspect those parts were an input shaft bearing - clearly not required until you remove the gearbox input shaft from the spigot bearing / flywheel...
I reckon Suby gearboxes are pretty good to keep going well without all those unnecessary bits in there...
Stay tuned. This will be interesting.
SUBYDAZZ
Outback bloke
Post by Outback bloke » Fri Jun 08, 2007 5:23 am
You should hold your foot flat on the throttle so the engine is on the rev limiter then bang the clutch out in 2nd gear on teh bitumen. It is a very quick way to find out where that bit of casing came from.
SUBYDAZZ
Post by SUBYDAZZ » Fri Jun 08, 2007 9:18 am
Roger that :)
SUBYDAZZ
Post by El_Freddo » Sat Jun 09, 2007 11:35 am
BYB-01 wrote:You should hold your foot flat on the throttle so the engine is on the rev limiter then bang the clutch out in 2nd gear on teh bitumen. It is a very quick way to find out where that bit of casing came from.
At the expense of the gearbox? I know you'd be prepared for the worst in this situation but if you couldn't find a gearbox or the time to change it wouldn't you just drive it nicely until you do have the time (or it breaks anyway giving you time...)
Just a query.
SUBYDAZZ
Post by SUBYDAZZ » Sun Dec 23, 2007 11:48 am
So my gearbox still works, but now jumps out of 3rd/4th so I'm thinking what Dave says is the goods. The initial problems I had here I also assume were partially the fault of the pressure plate springs just wearing out or losing their spring, as the clutch was not worn down as much as I had expected when I replaced the assembly.
SUBYDAZZ
