550kg? Dude what car is this?SCOOBIDOO wrote:I am not sure what they would be worth to buy nowdays..though i do know they are extremely well suited with the wolf 3d ecu... i am currently enjoying 155 hp in a 550 kg vehicle.....what would you consider to be fair pricing on this item?..cheers
EA82T "Spider" Inlet Manifold ?
- discopotato03
Not to worry , I think it would be possible to cut the ends off an EA82 MPFI manifold and fabricate something better than the L series one . I'd like to look into EJ manifolds and see what the plenum section is like volume wise . There may be a way to have the throttlebody mounted so that plumbing for a front mounted intercooler is easier .SCOOBIDOO wrote:Both manifolds are now spoken for..thanks for the speedy response...cheers
That pic of the engine with the red manifold , I noticed that the AC compressor and alternator are opposite way around to my 86 RX . Vortex ?
Cheers A .
90Brumby... those heads can be found on SUB4 website in NZ. it is their casting and they are not cheap talking car prices, but cheap aeroplane part prices. they have run their motor in their own blue brumby !! from memory they also make roler rockers for their heads and cast alloy covers to go with it !!!!
- SCOOBIDOO
beetles are 850kg
only an sti will lose this thing..12 psi jdm on optimax eqivelent...i went lighter and more power rather than trying to get a 1000kg car to go hard.....bikes under 500cc try to keep up...AndrewT wrote:550kg? Dude what car is this?
- show24[1].jpg (92.22 KiB) Viewed 3265 times
El_Freddo wrote:To use these spider manifold don't you need a different head that has separated ports similar to the EJ head design?
Just out of curiosity: would one of these increase performance on a NA EA82?
I wondered this too. You can get NA Spider Manifolds for EA82 - at least the States - but I think they are MPFI. Weld up the injector holes and adapt the throttle body inlet for a Weber
I've already got the MPFI, but a if the spider manifold made things flow better it would probabily be worth the look as i've just re-built the engine cancelling out an EJ conversion anytime soon...Fang wrote:I wondered this too. You can get NA Spider Manifolds for EA82 - at least the States - but I think they are MPFI. Weld up the injector holes and adapt the throttle body inlet for a Weber
The thing to look at if you were going to bolt a weber is how the fuel:air mixture flows through the manifold, you don't want saturation on the walls slowing fuel into the engine. It would be interesting to bolt one on and see what happens though.
- discopotato03
I was reading elsewhere that there is some slight difference with turbo and NA spider EA82 manifolds , possibly to do with water plumbing for the turbo . Thanks to Gee I now have such a manifold but not yet sure if its turbo or NA . He did not have the steel fuel and vacum pipes or throttle body so if anyone has them for sale please let me know . Its not the end of the world to make stuff up but the factory gear is usually easier and neater .
Cheers A .
Cheers A .
You can tell if it is turbo by a 12mm steel pipe that comes from the tubro water outlet to the thermostat on the intake.
If you are lucky, the throttle body off the normal intake might fit
