Fitting a weber
Engine, gearbox, diff & driveshafts
Re: Fitting a weber
Post by El_Freddo » Sun Aug 30, 2020 12:43 pm
Hey ‘91,
How do you know that cylinder 2’s piston comes up higher than the rest? I reckon that would typically show a much higher compression reading than the other cylinders if everything else is the same.
I can’t help with the Weber stuff - never played with them. For a Weber you’re about halfway into an EJ conversion depending on how you do it.
Return to “EA Drivetrain”
