Which is better CLSD or VLSD?
Which is better for off roading, Clutch LSD or Viscious LSD?
Poll ended at Wed Jan 10, 2007 8:36 pm
I don't know but i want one either way
15
83%
2
11%
1
6%
Total votes: 18
Post by AlpineRaven » Wed Jan 10, 2007 9:02 am
yes if its R160 diff then it can be done by taking out the LSD centre and put it in L series/Liberty Diff centre. Make sure you use the bearing housings from the wrx otherwise the bearings wont match the l series housing (where the shafts are).
Post by El_Freddo » Wed Jan 10, 2007 3:16 pm
Cheers AlpineRaven and Andrew T. This is something i wanted to know... now to add it to the list of things to consider and save for...
BRUMBI
Post by BRUMBI » Tue Sep 30, 2008 8:08 pm
i want a lsd, whats the easy way to convert will a vlsd from a rs turbo or such bolt straight into a brumby
84 MY Sportswagon
92 Brumby
87 Rx Turbo
Post by AndrewT » Tue Sep 30, 2008 8:21 pm
it will bolt in yes, but it will likely be the wrong ratio. the ratio must match the final drive of your gearbox. if you get an imported RS turbo diff it will probably be 4.111. It is possible to swap the VLSD part of it into your existing diff and use your existing diff ratios. search for the guide on how to do this, it's been covered a few times (at least once by me :) )
BRUMBI
Post by BRUMBI » Wed Oct 01, 2008 5:36 pm
cheers so by the sounds of its the rs turbo never came out with 3.7 diff
84 MY Sportswagon
92 Brumby
87 Rx Turbo
Post by Alex » Wed Oct 01, 2008 6:16 pm
BRUMBI wrote:cheers so by the sounds of its the rs turbo never came out with 3.7 diff
nup they most definately didnt.
i think they where mainly 3.9.
Post by AndrewT » Wed Oct 01, 2008 7:07 pm
import ones are 4.111
vincentvega
Post by vincentvega » Wed Oct 01, 2008 9:26 pm
All aus RS turbos had a 3.545 rear end. the rear diff isn't 3.9
Post by AndrewT » Wed Oct 01, 2008 9:37 pm
vincentvega wrote:All aus RS turbos had a 3.545 rear end. the rear diff isn't 3.9
just to make this clear for everyone....they do have 3.9 ratio gearboxes but the rear output is stepped down to 3.545. This means the VLSD from an aussie RS can basically not be used with any other suby gearbox unless you re-ratio it.
discopotato03
Post by discopotato03 » Thu Oct 02, 2008 1:35 am
Viscous hubs are not a serious limited slip device , they rely on a speed difference to limit the differential action if you know what I mean .
Manufacturers like them because they are quiet and "soft" on the drive line unlike any mechanical LSD .
Saulsbry (Sp ?) or clutch plate LSD's if you like are a load sensative device meaning they can load up and not spin unlike the viscous whimp . They work by the spider legs moving in beveled grooves in the hemispheres casing and load the clutch plates up even more that the static pre load does .
BTW you don't "shim up" a plate LSD you add extra plates and belville washers to increase the friction area and preload .
You won't find a front or rear Viscous diff in a serious rally car , maybe the center one in some Subies but not the others . Front or rear viscous ones slip too much , cook their fluid and then don't work at all .
A .
