ATT tt auto box owners.
- Suby Wan Kenobi
- stamp_licker
it gets better than that.try 6500rpm doing 30kph with motor cutting in and out.yeah i've checked and rechecked fluid levels.Now the torque conv just keeps on rattling.Have talked to a few auto experts and they all say nah them torque conv don't stuff up.one suggested i unplug the box wiring connecter,all of a sudden no slipping but the tc is still rattling and i've sprung a front diff leak at the axle.Looks like dodgee line pressure,unplugged it gives it full line pressure.Suby Wan Kenobi wrote:4000rpm stall is way too high for a std one, you sure its got enough trans fluid in it?
Anyone got the pinout for the tt auto plug on the box side i think some pins might need changing?
Building a hardcore postie:D
- Chris_Rogers
- Chris_Rogers
thanks christ I won't have to worry abou that!the_postie wrote:it gets better than that.try 6500rpm doing 30kph with motor cutting in and out.yeah i've checked and rechecked fluid levels.Now the torque conv just keeps on rattling.Have talked to a few auto experts and they all say nah them torque conv don't stuff up.one suggested i unplug the box wiring connecter,all of a sudden no slipping but the tc is still rattling and i've sprung a front diff leak at the axle.Looks like dodgee line pressure,unplugged it gives it full line pressure.
- stamp_licker
got told that today .geez you want to make sure you;ve got a bloody big cooler on there.Chris i've found another auto guy that nows heaps about the subaru auto's.The rumour is in about amonths time there will be a shift kit thats full manual no tcu required on the market$$$$$$$.Chris_Rogers wrote:so a VERY big cooler on it is a good thing (especially if there is a fan on it)
- Chris_Rogers
- vincentvega
mate why havn't you called Al about this? He knows more about these auto boxes than jsut about anyone, AND you bought the box off him...
im off to DI in the morning, wont be seeing you there by the sounds of it.. sorry to hear
Sounds like the auto is in 'limp' mode...
http://www.subiparts.com.au
0438 887 746
0438 887 746
- vincentvega
- stamp_licker
sitting still at the moment.the rattle is coming from inside the diff area,drained the oil rattle goes away.Dane ,Al tells me you have the 95 gx auto pinouts can i geta copy?Will have to check the pinouts box end i think line pressure etc might be crossed.i'm thinking the fwd tcu ain't gunna do it.Could be time to add the extra wires and run a wrex tcu or try the awd tcu with duty c disconnected.vincentvega wrote:any news postie? winning?
- Captain Obvious
ive got a awd tcu if you want to try it will!! came out of my car from when it was auto 3 plugs i think!!
- vincentvega
definately sounds to me like you have 12V up the line pressure solenoid = bugger all line pressure. How you have managed that though i dont know??
I have the pinouts at the TCU end only for the 95 model. I have all the diagrams for Gen1 but i gave you those..
I will try hunt something down for you.
- stamp_licker
- vincentvega
postie i have the same TCU in my shed.. might save you some postage getting it from byron.
When are you at home these days - i can drop round and give you a hand with this if you want? I am still confident the FWD TCU will drive this box, its gotta be a wiring problem
- stamp_licker
dane i agree with the wiring prob.My stab in the dark is the vss as this input affects a few different outputs,i'm running the one in the l dash but only connected at one point on the tcu ,there are 2 pins that run vss on the fwd tcu one from box one from dash they back each other up if one fails.also i sliced in the g/box plug of a awd loom as a couple of the pins from the fwd one didn't match the the box pretty sure i got the wires connected right lineWorking overtime lately so i don't get home to after 4.00 pm most week days, weekends i'm normally around.When is a good time to call you?And yes a hand in this would be GREAT.vincentvega wrote:postie i have the same TCU in my shed.. might save you some postage getting it from byron.
- vincentvega
