Center Caps ...
- TOONGA
I think he may mean the wheel locator like in this picture
from my disc install thread
showthread.php?t=14597
- Bantum
Line up ...
Ah - Ok if that's the case you just need to rotate the Center Cap until it fits :
See the 'gaps' in the retainer clips - they should line up with the 'peaks' on wheel hub locator ...
P.S. - This is the front of same Center Cap :
Cheers, Bantum ...
Cheers, Bantum ...
- Bantum
News to hand ...
I can confirm that Performance Wheels is about to close ...
So get in quick if you want anything from them, as stocks will dwindle by end of this year ...
Cheers, Bantum ...
Cheers, Bantum ...
- Silverbullet
^ Bugger ^
Just now walking back to the car at the shops I've noticed I've lost a center cap
I've got Performance wheels chrome hub caps like #15 in post 5 of this thread...they are a chromed metal can with a plastic top cap that can pop out for hub nut access, but the plastic cap isn't a perfect fit inside the can. A dicey design when I bought them I had a feeling they would pop out sooner or later. Now the search begins for a replacement, meanwhile I'm going to glue the other 3 in
- Bantum
Cap Retainers ...
This just in from UK :
Giles might do a better job at explaining these ...
Cheers, Bantum ...
Cheers, Bantum ...
