Ok, not a problem - However note that I'd only make one pair of wheels swivel ( preferably the front ones ) so when you lower it, you can make sure they don't hit anything + so you can still steer it too ... !60766244 wrote: ... The wheeled base/jack doesn't need to move anywhere near full extension. The movement won't need to be as much as in that photo. It's only to make the wheels contact/not contact the benches so the jacks will only need to move 100mm in height total ...
I'd try with a bit of an experiment first to see how much weight you can put on it before it buckles, you'd be suprised that it doesn't take much to do ...60766244 wrote: ... If the 5mm plate won't be good enough to lift the bench I will need to address the strength and brace it somehow. I'm fairly confident it won't dent or warp in though and I'm trying to keep bracing minimal. If I have to double the plate thickness (I have 10mm plate) I'd rather do that than more bracing above as I want to save the space ...
Was only ever ment to be used as an example, it would be easy enough to make a facsimile though ...60766244 wrote: ... The Toolmonger lift looks like a nice idea but at $500 for what I can do fairly easily for $5 doesn't really sit with me, as for the concept of it I like it, but the amount of extra engineering time to get a jack to work in that facility wouldn't be worth it in my book. If things start to look complicated, I'll simply do as suggested before and hide the mechanism under a flap ...
Ha - Don't forget that some other 'Nube' will have to be able to operate it at some stage ...60766244 wrote: ... There should be 0 wobble in the jacking process other than that I provide....
Yerp - I'd say Extreme overkill there too, it doesn't need the underlay, just the frame is sufficient.60766244 wrote: ... 5mm plate underlay. Extreme overkill ...
Good choice, I'd go for that ...60766244 wrote: ... I also have 40mm Jarrah too so I am considering using that for the benchtop also ...
I'd do a prototype first to work out any bugs before you go into 'production' - you could even do what I did and make a Maquette ( look it up if you don't know what it is ) this saves a lot of mucking about.60766244 wrote: ... I plan on making the decision once the frames are fully welded up and I get an idea of how heavy they feel ...
Anyway, good luck with it ...
Ciao, Bantum ...
