EJ20 N/A missing on all 4 cylinders
Post by RSR 555 » Thu Feb 21, 2013 10:39 am
taza wrote:Irregular flashes every 5-6 flashes it would miss one. All 4 clylinders did this at different times. The engine runs really lumpy
As a timing light uses an inductive clamp around the lead and being that the HT lead is insulated, it's too hard to get a constant spark rate. So it's hard to make the assumption that the spark is irregular.
Subydoug wrote:How well do Subaru's usually run open loop?
Perfectly. As Subaru use the coolant temp sensor until operating temp but I don't understand why you have asked this question?
Subydoug
Post by Subydoug » Thu Feb 21, 2013 10:56 am
Thought maybe the o2 sensor might have had a stick come up and damage it. Or dust in the connectors. Not sure how exposed it is under there. Obviously not the case if they run fine. Maybe make sure all your engine connections are clean?
Doug
Post by El_Freddo » Thu Feb 21, 2013 7:23 pm
RSR 555 wrote:
taza wrote:Guy and me
There's your problem right there :p
Bwhahahaha!!! :twisted:
My thoughts were the pretty much the same - sabotage by KPM!
Post by RSR 555 » Fri Feb 22, 2013 10:47 am
Subydoug wrote:Thought maybe the o2 sensor might have had a stick come up and damage it. Or dust in the connectors. Not sure how exposed it is under there. Obviously not the case if they run fine. Maybe make sure all your engine connections are clean?
It's a very good thought and yeah, can happen on some earlier ECU EFI systems.
Very good idea about the connections, as Taza is always playing in the dust and mud
Post by El_Freddo » Sat Feb 23, 2013 10:53 pm
RSR 555 wrote:Very good idea about the connections, as Taza is always playing in the dust and mud
I doubt it would be an issue - Subaru have very good sealing on their connectors! Unless he's been opening them in those conditions they should be fine.
Post by RSR 555 » Sat Feb 23, 2013 11:42 pm
You are correct Bennie, but as Taza's car has had the plugs 'connected & disconnected' a few times over the last few years, then it's worth considering.
I'm still leaning towards a skipped tooth on the belt. Here's a pic for Jonno
