im looking forward to finding outTOONGA wrote:
When I'm not looking after children or driving 240km in a round trip for work, I will find this mystery relay in my 89 brumby.
brumby starting issue
- thunder039
2004 subaru forester -gone
1999 subaru forester- no more
1989 subaru brumby- sold!
2008 zook jimny -sold!
- thunder039
not sure if the 87 brumby is the same as the 89 but i found this which helps with our answer
http://www.answerbag.com/q_view/743527
what cant google find
- Bantum
Check ...
1. not unless you want to ...thunder039 wrote: 1. no need to rip up my floor vinal to check the relay unit?
2. there is no relays for the fuel pump?
3. therefore the only things it could be is a block, a stuffed pump or a fuse?
2. definitely, cut of switch yes - no relays ...
3. all possible, you just need to go through the elimination process ...
- thunder039
finally got a chance to look at the car today.
first off checked the fuse= good
so i went to strait to the fuel pump.
i blew air down the fuel lines that headed from the pump to the engine still no go.
the fuel pump does pump i can hear it, but no fuel is coming out of the pump
the filter before the pump has fuel and isn't blocked (fills up when emptied)
so could the pump still be stuffed even though i can hear and feel it pumping?
- littlewhiteute
- thunder039
try blow through the pump- to- tank line ?
If your needle and seat is stuck on float bowl is full position you can be tricked into thinking fuel pump is no good. I was tricked once, and had to buy a new pump that still left me stranded outside the Ford dealer. Ford had to be towed home by a Holden
until I found the Holley anti splash guard for bowl vent hole (crude eh?) on the 465 four barrel was fitted to the wrong side of the retainer gasket,(by me !
) subsequently fel into the float bowl, sloshed around on the bottom and occasionally would jamb its wedge shape under the float as I went up inclines, like the one outside the Ford dealer
- thunder039
- Bantum
Test ...
I'd remove the pump ( clean & inspect while your at it ) & do a 'bench' test with a suitable tank etc, to see if works correctly ...thunder039 wrote: ... so I went to strait to the fuel pump ...
... could the pump still be stuffed even though I can hear and feel it pumping ? ...
- thunder039
SHE LIVES!
well i went and just replaced the fuel pump with a spare pump on my parts
brumby which luckily worked so its all good now im thankfull it was just the pump
- TOONGA
Well done good to see it wasn't the fuel cut relay
So I have had time to look for this elusive box of tricks that doesn't exist.
instead of breaking my neck I got my trusty camera to do the hard work nope not there.
anyone have any idea what those 2 relays do? I turned my hazard lights on the flasher relay clicked but not either of them.
Hmm I wonder if I pull the change holder where I can hear the the indicator relay can it be accessed ... wait WTF thats not the flasher unit ... ZOMFG thats it the elusive fuel cut relay
and whats that next to it ... it was still clicking when I took these photos
you can see the flasher unit (sort of) next to the fuel cut relay.
and read here for my little brumby won't start saga
- Bantum
Nope not there ...
Correct - dosen't exist ...TOONGA wrote: ... So I have had time to look for this elusive box of tricks that doesn't exist ...
TOONGA wrote: ... anyone have any idea what those 2 relays do ? ...
They are headlamp relays ... Items 29 + 30 ( going by wire colours )
Umm - No it's not ... It's Item number 16 on wiring diagram ... Intermittant wiper control unit ...TOONGA wrote: ... wait WTF thats not the flasher unit ... ZOMFG thats it the elusive fuel cut relay ...
P.S - That wiring diagram I refered to is pretty close to what every Brumby has, as posted elsewhere - When they made them in the factory, they used the same loom in just about every other MY model - So don't go reading too much into it, just ignore the bits that don't belong to the Brumby ...
- TOONGA
ha haBantum wrote:Correct - dosen't exist ...
ah okBantum wrote: They are headlamp relays ... Items 29 + 30 ( going by wire colours )
That would be correct if the car was a 1982 -4 wagon or American delivered BratBantum wrote: Umm - No it's not ... It's Item number 16 on wiring diagram ... Intermittant wiper control unit ...
- Bantum
Wire Trace ...
To make sure - Find out where the wires go + what colours they are ...TOONGA wrote: ... That would be correct if the car was a 1982 -4 wagon or American delivered Brat ...
Then see if they match the wiring diragram ...
- thunder039
another phew as those cut out relays are about the 4 hunge mark or more exJapan.
Those relays side by side are the common old 22A Mitsu Fuji used almost everywhere for generations in our Subes as ignition, fuel and light relays. think those two are left and right configured.
The old shove-the-camera-in-the-hard-to-see-location is great eh ?
Thunder - make sure you toss the crapped out pump so it don't end up as a maybe it was a good one in a few years time.....
These pumps are cheap enough to have a spare rigged up for emergency repair diagnostics. Bit like having a spare coil mounted under the bonnet, spare module in the glovebox .....
- thunder039
phew lucky thensteptoe wrote:another phew as those cut out relays are about the 4 hunge mark or more exJapan.
yeo went straight in the skip bin
