Bought another Brumby today
Post by El_Freddo » Mon Jun 11, 2012 11:53 pm
revmax wrote:sorry here a re a couple of photos. See is rough around the edges but has potential
To be shiny like you're other red brumby? What is it with you and red brumbies??
alang wrote:now your getting the rest of us thinking :D is their a posting on here for doing this conversion sounds good the ea81 in the brumby sounds good just got it going again after 2 years sitting no smoke out the back. then again the mate just gave me a ej22 motor block no heads
You can read about my gearbox build in Ruby Scoo, it's basically the same, just the other way around. Mine was EJ casings with EA5spd internals. You can do EA5spd (L series gearbox) casings with EJ internals as well - but you have to build up a dedent ball to hold high/low range where it needs to be.
There's also a super old thread about this theory that I started many moons ago! here it is back when I was a noob. These day's I'd just build the box and be done with it! I'd just need to learn how to do the diff adjustments properly and I'd be set I reckon.
thunder039
Post by thunder039 » Tue Jun 12, 2012 9:08 am
pretty clean brumby only a few little dings and the paint isnt to bad for age
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
revmax
Post by revmax » Tue Jun 12, 2012 1:07 pm
thunder039 wrote:pretty clean brumby only a few little dings and the paint isnt to bad for age
drivers door has been kicked in and the tailgate backed into.
Put an inner TR end on yesterday.
Motor runs OMG SOOOOO nice.
Gear lever needs a knob.
Air con and heater doesent work, think it is an electrical fault.
At Pro align right now getting a wheel alignment. One rim is bent to the shit house and needs replacing.
Came with a new CD player/head unit but needs wireing in.
revmax
Post by revmax » Tue Jun 12, 2012 1:09 pm
El_Freddo wrote:To be shiny like you're other red brumby? What is it with you and red brumbies??Bennie
I have a white one and a black one too.
revmax
Post by revmax » Mon Jun 25, 2012 6:47 pm
Auto sparky found a blown relay.
Genuine Gear knob fitted
sloppy shifter fixed
Wheel alignment was unsussefull. WAFTAM
Post by El_Freddo » Tue Jun 26, 2012 12:36 pm
revmax wrote:WAFTAM
Nope, can't work this one out :(
And why couldn't they do the alignment??
Backyard_Brumby
Post by Backyard_Brumby » Tue Jun 26, 2012 2:01 pm
WAFTAM
Suspect he meant WOFTAM - Waste Of F.....g Time And Money.
I also would like to know why the alignment didn't work?
[SIGPIC][/SIGPIC]James :D
revmax
Post by revmax » Tue Jun 26, 2012 6:41 pm
Backyard_Brumby wrote:Suspect he meant WOFTAM - Waste Of F.....g Time And Money.
correct, I not real good spella.
could be a few things, with the wheels off the ground and steering wheel straight the wheels point to the right.
Gunna have to wait till saturday to sort it
revmax
Post by revmax » Sun Jul 01, 2012 6:23 pm
over the weekend I fitted front exhaust from an l series with catalic converter, cause it had no cat fitted.
Removed oil filter and fitted another which I had "prepared earlier"fitted new o rings and gasket.
Oil pump is easy to do with radaitor removed
Flushed the coolant system and filled with fresh coolant.
Removed the long thermostat housing and hose and fitted a STD housing and hose so i can use the long housing and hose on B1
Took her for a 20km drive at 110kmh and no oil leaks from pump, a bit still weaping from the sump gasket though.
alang
Post by alang » Sun Jul 01, 2012 9:04 pm
revmax wrote:over the weekend I fitted front exhaust from an l series with catalic converter, cause it had no cat fitted.
sounds like a drive down to Repton and back to me
Post by El_Freddo » Sun Jul 01, 2012 9:14 pm
revmax wrote: could be a few things, with the wheels off the ground and steering wheel straight the wheels point to the right.
Did you install the correct inner tie rod (rack end)?
revmax
Post by revmax » Mon Jul 02, 2012 6:46 am
spot on Alan.
Bennie, yer Mate I took it from a spare rack I had.
It drives fine now, must have been a tyre issue. This brumby is now fitted with the wheels and tyres from B1 as i had a fresh set of wheels and tyres in the shed just busting to go on B1.
revmax
Post by revmax » Thu Jul 05, 2012 6:45 pm
she scrubbed up OK.
revmax
Post by revmax » Thu Jul 05, 2012 6:47 pm
interior
thunder039
Post by thunder039 » Thu Jul 05, 2012 7:39 pm
scrubbed up real well looks great! the red isnt to faded too which is good to see. seems like the young fella looked after it
revmax
Post by revmax » Fri Jul 06, 2012 5:13 pm
Listed it on Gumtree less than 1hr later, Some bloke spotted it and wanted it so he bought it. It will spend some time out Taylors Arm way now, no doubt a long time.
thunder039
Post by thunder039 » Fri Jul 06, 2012 7:16 pm
i didnt realise you were selling it
