1989 MPI EA82 distributor & rotar
AUSubaru Technical Manual. Collaborative Tech Manual for ALL Subarus.
OKsubaru
Post by OKsubaru » Fri Feb 03, 2012 12:07 pm
Huh ? Someone acting on my behalf?
It would be a good idea now to make a new thread , with a link enclosed to this one, Got EA82 mpfi NA title, explain and ask for others to report back their dizzy part numbers.
I can supply offa NA carby 1987 as comparison
Mark_G
Post by Mark_G » Sat Mar 03, 2012 12:31 pm
Subaru had the parts imported from Japan in about a week and a half (picked them up and installed them 15/02/12) - Cost for distributor and rotor $116.10. Distributor cap part number 2216AA040, Rotor part number 22157AA001
New Rotor.jpg (29.44 KiB) Viewed 33567 times
EA82 Dissy_Rotor.jpg (36.84 KiB) Viewed 33571 times
Post by steptoe » Sat Mar 03, 2012 5:26 pm
Just got same vehicle and reading this....
thse dizzies use the ECU for their advance etc ..... not just a stand alone dizzy eh ?
LT65
Post by LT65 » Sat Mar 03, 2012 9:54 pm
I have the same engine in my Brumby and have had little luck in finding the correct cap also, purchased one from the UK only to find it was wrong. Unfortunately I don't have a VIN from the donor vehicle to go to Subaru with, so today I purchased a new distributor in the shape of a very bent 2006 Impreza wagon for its NA EJ204 and 5 speed dual range AWD trans. Let the games begin.
___________________
Lionel.
91 Brumby EA82 MPFI
09 Cobra replica 6.0l chev
revmax
Post by revmax » Sat Mar 03, 2012 9:58 pm
LT65 wrote:I have the same engine in my Brumby and have had little luck in finding the correct cap also, purchased one from the UK only to find it was wrong. Unfortunately I don't have a VIN from the donor vehicle to go to Subaru with, so today I purchased a new distributor in the shape of a very bent 2006 Impreza wagon for its NA EJ204 and 5 speed dual range AWD trans. Let the games begin.
OH YER ! Let the pussy cat growl !
LT65
Post by LT65 » Sun Mar 04, 2012 11:17 pm
I have done a little more searching and have discovered this distributor cap no 22162AA040 also fits 6/86 to 2/89 Suzuki Swift 1.3i 16v and Nissan Terrano 2 Z241.
other manufacturers part no's Standard motor products JH180, Airtex/Wells 5D1242, QH XD297, Intermotor 45471, Suzuki 33321-641310, Lucas DDJ, Hitachi 44588-17001,Nissan 22162-17M03/4/5.
Good luck
___________________
Lionel.
91 Brumby EA82 MPFI
Post by steptoe » Mon Mar 05, 2012 3:26 am
That Nissan part number partially rings a bell don't it - thanks for posting up your find. I found the GH623 has a listing for heaps of Nissan applications yet not listed for Subie at all - subybrumby made the discovery.
Wonder what you come up with searching 22162AA020 ?
PhilsWagon
Post by PhilsWagon » Wed Mar 05, 2014 3:20 pm
Anybody get any further with generic options for dizzy cap and rotor?
Auto pro/supercheap/repco don't have any listings.
Subaru Australia says they don't stock them (22162AA040 - Cap & 22157AA001 - Rotor) have to be shipped from Japan and want $130ish for the pair!?!?
I've found some options on ebay in the US but am a bit cautious after the timing belt kit I ordered came with no box and with 2 damaged right hand tensioner pulleys.
Any help would be awesome!
Post by RSR 555 » Mon Mar 10, 2014 12:16 am
I have 2 listings for EA82 EFI dizzy caps and rotors. Either clip on or screw on cap, also if it's Nippon or Hitachi dizzy.
Have you got any pictures of your cap?
PhilsWagon
Post by PhilsWagon » Mon Mar 10, 2014 9:41 am
It's a Hitachi screw on cap and the rotor screws on to the dizzy shaft as well.
I'll post some pics when I have a chance.
Thanks RSR555
tony
Post by tony » Mon Mar 10, 2014 8:01 pm
tidying up found a dizzy and cap dizzy no is 22100aa450 d4p86-01a8x03
height of cap from base of cap to tip of spark plug lead holder is about 64mm give or take a mm
it came off a ea82 i blew up.
any interest?
can't do pic my camera lead has gone missing.
Post by steptoe » Tue Aug 12, 2014 7:38 pm
Just been fiddling with an optical dizzy from EA82T part number ending in AA410.
The rotor button I ran on my SeriesOne L Series mpfi EA82T Bosch GH605 measures up same when fitted - just no brass internal bushing or retainer screw to sh!t you. Looks a lot less plastic in the 605, but looks like it will do the job
The brass contact for the caps terminals is same 36mm above a point on the dizy body for both rotors
Return to “Tech Manual”
