Impreza 2L gx ignition switch wiring diagram
GTFOZZY
Post by GTFOZZY » Fri Feb 10, 2012 11:04 am
Yeah but it was doing it before we cleaned yit and maybe it wasn't airflow but it was something someone said on here to clean :/ and I dont have a car to swap with :/
Now-00 Impreza 00 GT Forester
Then-5xVortex's Glf Hardtop
Post by RSR 555 » Fri Feb 10, 2012 11:59 am
How far away from Al's Autos are you? May pay just to call and drop in to see him. There is definately something not right.
Have you had a compression check done?
Are you sure all the vacuum and boost lines are connected?
GTFOZZY
Post by GTFOZZY » Fri Feb 10, 2012 4:34 pm
I haven't heard of al's autos sorry are they in qld?anyways i'm booked in to my nearest non dealer subaru mechanic on Tues wish me luck lol
Post by RSR 555 » Fri Feb 10, 2012 5:33 pm
Yes mate, all the best and if it turns out to be the MAF sensor then check this mob out...
http://wa.gumtree.com.au/c-Cars-Vehicle ... Z333114659
Oh and yes, Al's Autos are in Qld and highly recommend by many on here.
Post by Gannon » Fri Feb 10, 2012 5:49 pm
Would a 2000 model Impreza have an air flow meter? Im pretty sure that it would have a MAP sensor.
Post by RSR 555 » Fri Feb 10, 2012 6:05 pm
Gannon wrote:Would a 2000 model Impreza have an air flow meter? Im pretty sure that it would have a MAP sensor.
Oh yes.. sorry thought we were talking about the Foz.. sorry my bad... Face palm
Post by Gannon » Fri Feb 10, 2012 6:07 pm
Ah... check out the title of this tread?
Dont worry, I wont tell anybody. ;)
Post by RSR 555 » Fri Feb 10, 2012 6:12 pm
Oops... What an idiot :(
Umm.. well hopefully the mechanic can be better help than me... Sorry
Post by El_Freddo » Fri Feb 10, 2012 9:26 pm
RSR 555 wrote:Oops... What an idiot :(
You do alright for someone on the other side of the continent when all you've got to go by is the forum member's observation skills :rolleyes: Geez, anyone would think there would be something wrong with you for all the help you give out :mrgreen:
Post by Gannon » Fri Feb 10, 2012 10:22 pm
So have all your ignition leads been replaced. I got replacement Bosch ones for my Outback from the local parts guy. I just took my old leads in, and matched them up to the ones on the rack and chose the ones that matched, cost about $12 each.
My other suspect is fuel pressure, either from a faulty regulator or pump. You will need to test it, but this may be a job for a mechanic because working with high pressure fuel can be dangerous.
The fuel pressure should be 36.3psi when you turn the ignition on, but dont start the engine. When the engine starts, the fuel pressure should drop by nearly 10psi because the manifold vacuum controls fuel pressure
GTFOZZY
Post by GTFOZZY » Sat Feb 11, 2012 6:56 am
yep thanks guys all a bit to complicated.Anyone think it could be the cat converter as there is some exhaust burble and can not find a hole in the exhaust .anyways hope get answers soon hey :)
Post by Gannon » Sat Feb 11, 2012 7:43 am
Nah it wont be the cat. A blocked cat makes it feel like you are driving with the handbrake on, and there will be no exhaust burble
GTFOZZY
Post by GTFOZZY » Tue Feb 14, 2012 4:49 pm
So guys got tested and suprise it's the........coil and should do other leads as well :/ at least I got an answer lol
Post by El_Freddo » Wed Feb 15, 2012 10:27 am
Let us know how it turns out GT ;)
GTFOZZY
Post by GTFOZZY » Wed Feb 15, 2012 11:31 am
Yes I will have ordered the coil am just thinking i might try it with the leads I have as we replaced 3 which tested faulty the others were ok ,I'm on a budget here lol.Let ya's know :P
Post by RSR 555 » Wed Feb 15, 2012 2:42 pm
Check the resistance of the leads with a multimeter.. you may find they are the major issue.. very rear that the coil fails.. when this happens you lose spare to 2 cylinders, as they use a waste spark setup.
GTFOZZY
Post by GTFOZZY » Wed Feb 15, 2012 8:00 pm
We used a multi meter and number 3 was faulty.The old mate at the mechanics said they only had the same model impreza in last week with a same prob it had 220k mine has 320k and has never been changed so i dunno they put on computer and test drove it and said that it for sure,if it's not they guna hear bout it lol
GTFOZZY
Post by GTFOZZY » Thu Feb 23, 2012 8:51 pm
Ok so coil and leads replaced car back to old self :) thanks god! :P
Post by NachaLuva » Fri Feb 24, 2012 11:13 am
GTFOZZY wrote:Ok so coil and leads replaced car back to old self :) thanks god! :P
Great to hear...hate to think how much the coil cost :(
GTFOZZY
Post by GTFOZZY » Sat Feb 25, 2012 12:06 pm
yes well money is tight so didnt get a genuine picked up leads and coil on ebay $200.Anyways all good finally :)
