NOOB moding '09 Forester!
taza
Post by taza » Mon Jan 30, 2012 9:05 pm
Jerrad wrote:Hrm, hit abit of a snag...
Insurance company wont insure car if you change suspension more then 30mm!
Any one else have this problem? I was just about to do a bulk order of things!
Thats a load of cr@p. 50mm is the legal limit, they should suport that. But anything more and you need an engineering certificate.
I would change companies!
Post by NachaLuva » Mon Jan 30, 2012 11:50 pm
taza wrote:Thats a load of cr@p. 50mm is the legal limit, they should suport that. But anything more and you need an engineering certificate.
+1.
Or at least ring around...
Jerrad
Post by Jerrad » Tue Feb 07, 2012 9:16 pm
G'day fellas!
Im looking for 5x cheap 16" wheels or rims so I can have 2 sets of wheels, 1 A/T and 1 roadys.
Im at abit of a stand still with my off-road mods, Insurance companies suck! so shopping around. Im also in training for the Kona Otway Odyssey 100km of Mtbiking!
I cant Post in the "wanted" section.
Thanks! Jerrad!
OFFROAD NOOB MODDING
Brumby Kid
Post by Brumby Kid » Wed Feb 08, 2012 7:30 am
Jerrad wrote:G'day fellas!
Good Idea Jerrad!
Yep they can do.
Awsome! you must have some pretty strong legs! And will power!
You need to be subscribed to post there.
Cheers Cam
Dads Car: 02 Impreza WRX STi
spike
Post by spike » Wed Feb 08, 2012 2:48 pm
only registered members can post in the wanted/for sale. but keep an eye on them and post here i guess (but dont keep bumping it and all that crap)
there are some retractable cargo barries (JDM??) that go up and down instead of over the top of the load
maybe look into them?
yeah legal limit can be what it is but insurance is whatever and all that, id post on 4wd action or somthing or just search for info there as they go higher and still legal
B00sting
Post by B00sting » Wed Feb 08, 2012 5:01 pm
Give Shannons a call.
For modified cars can't beat them.
Just make sure you can demonstrate some basic level of interest in cars on the phone (i.e in a club, subscribe to mags, do your own mechanic work etc).
-97 Landcruiser :D
Jerrad
Post by Jerrad » Thu Feb 23, 2012 8:13 pm
Ok so Im back! Time to actually get into my MODs! Iv been training for the "kona otway odessey"! 100km with about 3000m vertical Mt Biking! It was great fun on the weekend and Id do it again, I was a little sore and stiff but fine otherwise.
So I have a GME 3100 and antenna, light bar, driving lights, and I am thinking of going to get a ARB CKMA12 on friday and install it this weekend!
I am going to stay with my shitty insurance for the moment and just get a 1" lift and am going to make a sump guard at work out of checker plate!
Quick QU:-
-What is the best way to join the HIGH BEAM wire and the wire for relay for the driving lights? I dont like the idea of the clip that pierces the 2 wires, no water proof or anything.
-Where/how is the best way to get a wire from the engine bay into the cockpit?
Ill try take heaps of photos and do a write up for each. I have yet to do any MODs so I mightnt actually finish or work it out and the write ups might take time.
Any tips before I start? haha!
1 Starter pic, whats best way to do pics?
Thanks! Jerrad!
pitrack_1
Driving light wiring
Post by pitrack_1 » Sat Feb 25, 2012 2:03 am
Jerrad wrote:Ok so Im back! Time to actually get into my MODs! Iv been training for the "kona otway odessey"! 100km with about 3000m vertical Mt Biking! It was great fun on the weekend and Id do it again, I was a little sore and stiff but fine otherwise.
On ya mate! :-)
Jerrad wrote: Quick QU:-
1. The Hi-beams are controlled through a relay.
2. The hi-beam relay solenoid is controlled by the body control unit (BCU) computer/box.
3. The hi-beam power comes directly from a +ve 12V rail, though a fuse, the relay and back to ground (I assume).
Click each pic below for a larger version.
a) The driving lights should be wired on their own separate circuit, through a fuse and relay.
b) Because of (2.) you shouldn't connect the driving light relay solenoid in parallel with the hi-beam relay solenoid. You may interfere with the BCU, overload the circuit, cause ground loops/ external grounds, etc.
c) Because of (3.) the driving light relay solenoid can be wired in parallel with the Hi-beam bulbs. The extra power draw (from the SOLENOID) will be very small compared to the hi-beam bulbs and shouldn't interfere. It's easiest to tap in at/near a hi-beam bulb. Run from the hi-beam +ve, through the cockpit switch, relay solenoid, and back to hi-beam -ve/gnd. See my pic for the tap-in done by an auto-elec.
d) Where the cockpit switch wires can be run through the bulkhead[/url]. I don't know if that rubber grommet/bung was there to begin with or not.
e) Wire the power for the driving lights from the +ve battery terminal, through an in-line fuse, to the driving lights (don't forget they go in parallel with each other) and back to the -ve battery terminal or good chassis ground. Be careful about the ground, don't use an electronic/harness one just in case you get some weird effects. On that, better just go back to the battery straight :-)
f) Use good ring terminals at the battery as they'll carry a reasonable amount of current. Inline fuse for safety, and you should be able to buy splices/wire joiners- you just need to actually cut the cable, strip the ends and crimp them in. Tape up with electrical tape.
g) You can also see my thread on fitting driving lights.
Jerrad wrote:whats best way to do pics?
Try photobucket. You'll need a login (just register one) It will give you links to paste in. The instructions for including images and files are in the FAQs. Note if you make pics come up inline please make sure they aren't too big. You can link bigger ones as I have done.
Jerrad wrote:Any tips before I start? haha!
I think I saw from your photo you have the original Bridgestone Dueler H/T 687s? See what happened to me. One dead tyre may mean 4 new ones (or you can stuff the AWD system). If you're going to be off-tarmac a lot, watch out and run lower pressures (30psi i've been recommended) or get better ones.
Have fun and don't destroy anything on that shiny forester!
Patrick
Ex- 2010 Forester Diesel
Jerrad
Post by Jerrad » Sat Feb 25, 2012 10:48 am
Thanks heaps pitrack!
That photo was taken a little ago over in WA, all my new pic's seem to be from the back or side corners. I have changed my tyres to 'Cooper CS4' a while ago and no problems off road so far! Need to get some new rims and some AT's for some real offroad.
Iv had a little busy morning but am hoping to get into it now!
Thanks!
Thanks! Jerrad!
Jerrad
Post by Jerrad » Sat Feb 25, 2012 10:31 pm
Once again Thanks PITRACK! I have got the radio and driving lights installed! though I am going to have to do something better then the light bar! Its flimsy and driving lights push hard on the plastics!
Write up and pics will follow
Thanks! Jerrad!
pitrack_1
Thanks and CS4s
Post by pitrack_1 » Sun Feb 26, 2012 12:13 am
Glad to be of help, Jerrad!
Saved you the time & cost of an auto-elec at any rate. I wasn't game as didn't have the wiring diagram at the time and have heard some bad stories. Anyways, I can't even get the damn plastic covers off the engines nowadays!!! :mrgreen:
A 'nudge' bar such as on my driving light thread sorts things but costs $$$.
How do the CS4s go? I was considering them along with the A/T-S and H/T-S. Plumped for the A/T-S based on forum recommendations and my desire (image dreaming?). They're very stable on unsealed roads and on-road are quite reasonable (good in wet) but can be a bit wandery and vague at high pressures, and squirmy esp if cornering hard. Comfortable and quiet too. Even the wife is happy! They're a really good balance of duties and qualities. Just don't try to beat the amber right-arrow by "brake deep into the intersection, turn in and drive out" as the results are...untidy :grin:
It's a pity they don't come with the white lettering for the Forester 16" size, would've looked OK- I think.
Next time I might revert back to more hardtop bias CS4 or H/T-S as that's most of what the vehicle does.
Patrick
Jerrad
Post by Jerrad » Sun Feb 26, 2012 8:25 pm
Did I link photos properly?
CB GME 3100
Lights (to be removed)
ProRack Roof Racks and Fork Mount Bike Carriers for my 2 Scott Genius's
Thanks! Jerrad!
pitrack_1
Pictures now missing
Post by pitrack_1 » Tue Feb 28, 2012 2:44 pm
They were OK on the subaruforester.org forum a couple of days ago but they're not available either there or here now.
They're back! And even better than before.
Patrick
Jerrad
Post by Jerrad » Wed Mar 07, 2012 8:01 pm
Thanks everyone for your help and advice!!!
Well... Everything has to be put on hold! I was hoping to get the lifts and once ordered them I was going to order BullBar! Then I was going to get all my camping gear I needed and do a trip upto Fraser Island before winter!
NOW however I am flying over to WA on the 16th until after easter weekend! Then overseas! Im not meant to return till the 30 June at the latest. Going to see some good interesting places though! Ill still be reading and trying to do as much research while away!
Ill do my ordering while away and hope it will all be here when I get home and I can take holidays to install then take a long trip!
Thanks! Jerrad!
Jerrad
Post by Jerrad » Wed Mar 21, 2012 10:02 pm
Well I have been abit busy at work and at home, but Iv been doing a few things.
I did a trip with the Vic suby club on the Labour day weekend and had a BALL!!! Cant wait to get out again! The car as stock went very well and surprised me and I think a few of the others as well!
I have since added-
ARB Awning, I had to make brackets for my pro-rack's
Finally finished my sump guard! Well almost, I still have to take it back off and prime and paint it next week! Will look nice black checkerplate!
Iv also added to my supplies... ABR Compressor, MaxTrax, recovery hitch, speedy seal and some camping stuff, still not decided on fridge (brand/size, want it to go under boot cover) or cooker/stove... I am going to wait on the swag/rooftent/tent/car thing.
I have bought 4 new rims too! These getting delivered start next week, trying to buy 2 more locally and paint these black too! Going to TRY put Cooper A/T tyres on them! currently run 65, going to see if I can run 75s?
Thanks! Jerrad!
thunder039
Post by thunder039 » Thu Mar 22, 2012 1:22 pm
the forerster looks awesome mate! ood to see some people taking late model cars out in the bush!
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
B00sting
Post by B00sting » Thu Mar 22, 2012 7:54 pm
hey mate,
where did you go with the vic suby club?
any footage taken?
-97 Landcruiser :D
Jerrad
Post by Jerrad » Thu Mar 22, 2012 8:46 pm
The Brumby on the Vic Subaru Trip, we went upto Big River!
Me at Big River, Iv not got the river corssing ones yet
Awning after Install
Sump Guard Insalled
Thanks! Jerrad!
Post by NachaLuva » Thu Mar 22, 2012 10:18 pm
Nice pics Jerrad.
Love your new sump guard :mrgreen:
Interesting snorkel on the brumby ;)
B00sting
Post by B00sting » Fri Mar 23, 2012 6:41 pm
I could name all the places in those pictures!
This is not against you but man there are some huge wankers that go up there!
I often work up there and the damage done is astonishing sometimes...
-97 Landcruiser :D
